Author Topic: Upgrading a stock 340 - 1973 Cuda  (Read 1925 times)
Offline Glow Worm
« on: November 21, 2015 - 11:17:35 AM »
My 73 Cuda, as far as I know, has the original, unmolested 340 engine in it.  The car has approximately 58, 500 miles on it.  I would like to try to get a few more horsepower out of it.
A very good friend of mine told me that putting different heads, intake and cam will help, but unless I am willing to change the pistons, and do some other upgrades I will be throwing money down the toilet.  He says the engine has low compression because "the pistons are buried in the cylinders."  I'm not a mechanic, but I do understand that.
My initial thoughts were to buy an Edelbrock top end kit and just go with what I got, but after talking about it, I'm thinking I should go with the entire rebuild.
What could I expect if I just went with the top end kit?  I need to have the engine bay painted and I want to do the transmission too while everything is out of the car.
Any thoughts?  Suggestions?
"If I had all the money I've spent on cars . . . I'd spend it on cars."
Offline 73_Cuda_4_Me
Re: Upgrading a stock 340 - 1973 Cuda
« Reply #1 on: November 21, 2015 - 05:31:18 PM »
What do you want to do with the 73? What gearing in rear? Open rear or limited slip? Just depends on what you want to do and how much you want to spend...
 :burnout:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline cudabob496
« Reply #2 on: November 21, 2015 - 05:47:40 PM »
you can put free-er flowing heads on there, with a smaller combustion chamber, that will increase compression ratio, and power
pretty signficantly.
2011 Kawasaki Z1000
Offline moper
« Reply #3 on: November 21, 2015 - 11:05:19 PM »
You're friends are talking about the compression height of the pistons vs the deck height of a non-blueprinted block. In the later-than-'71 engines the pistons are shorter. So the actual measured compression is closer to 7.8:1 than the 8.5:1 they advertise. It's not a big deal. The 340s still capable, but you want to make sure you don't over cam it. Stay conservative (under 225 degrees at .050) and you will get some power without serious work. I don't feel that new heads are worth the investment without addressing the pistons. But a cam, intake, and headers will ceratinly go along way to a wider smile.
Offline YO7_A66
« Reply #4 on: November 22, 2015 - 11:07:22 AM »
 My 1970 340 started out as a stock rebuild (OE) when I bought it 14 years ago. I too wanted something more out of it so I started swapping out parts over the years. I swapped out ignitions, carbs, intakes, cams, intakes, HP exhaust manifolds to TTi headers, stock 2-1/4" exhaust system to a 2.5" X-pipe system. After all of the parts swapping that I have done, the biggest "Seat Of The Pants" feel did not come from any of these engine parts.
 The biggest "SOTP" changes were swapping from 3:23 gears to 3:91's, and swapping from the stock torque converter to a 10" 3500 unit.  :thumbsup:
Offline cudabob496
« Reply #5 on: November 22, 2015 - 05:39:50 PM »
heads are supposed to be the #1 place to go for added power
2011 Kawasaki Z1000
Offline cudabob496
« Reply #6 on: November 22, 2015 - 08:32:39 PM »
here's an easy 50 hp:
free flowing 2.5 inch exhaust with X-pipe, Walker super-turbo mufflers
headers
cold air induction
K&N air filter
tune-up, including carb
then to be quick on street, 2800 stall converter, and around 3.70 rear gears.
« Last Edit: November 22, 2015 - 08:34:49 PM by cudabob496 »
2011 Kawasaki Z1000
