Author Topic: Torque Monster  (Read 3112 times)
Offline cudabob496
Torque Monster
« on: November 22, 2015 - 03:46:42 AM »
2011 Kawasaki Z1000
Offline YellowThumper
  • I left the snow for this?
Re: Torque Monster
« Reply #1 on: November 22, 2015 - 01:19:50 PM »
No words other than ouch...
Dropped a front u joint and driveshaft dug in is my guess.
Offline Cudakiller70
Re: Torque Monster
« Reply #2 on: November 22, 2015 - 01:48:22 PM »
Wow what a mess, incredible when you think about it the rear end ripping out like that!
The above is just my opinion
John Adams
Offline 1 Wild R/T
Re: Torque Monster
« Reply #3 on: November 22, 2015 - 02:27:35 PM »
Axle saddle welds let go... Once the axle starts to rotate & the driveline angle gets to the point things bind somethings gonna break...
Re: Torque Monster
« Reply #4 on: November 22, 2015 - 02:47:10 PM »
So this is more likely something else happened, that a drive shaft safety loop would not of prevented, but maybe helped?  :dunno:
John Adams
Offline cudabob496
Re: Torque Monster
« Reply #5 on: November 22, 2015 - 04:30:50 PM »
I recently went to a stronger drive shaft with beefy U-joints.  I think that was
the weak link in my car.
2011 Kawasaki Z1000
Offline TelisSE440
Re: Torque Monster
« Reply #6 on: November 22, 2015 - 04:38:25 PM »
Thankfully no one got hurt, makes me think where should someone should give special attention, regarding the shaft and the differential...
Offline cudabob496
Re: Torque Monster
« Reply #7 on: November 22, 2015 - 08:03:33 PM »
or at least get under there and check bolt torques.
its pretty easy to build a drive shaft loop, at least one to keep it from
pole vaulting.
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: Torque Monster
« Reply #8 on: November 22, 2015 - 08:10:33 PM »
Driveshaft loop wouldn't matter, better welds would.. Likely the axle had been changed, new perches located the axle but either the perches were welded with poor penetration or it was just tack welded & someone forgot the next step.... The car didn't have enough traction to tear out a properly welded axle... In drag race applications you'll see the axle start distorting the perches, when that happens typically the perches get boxed & additional support brackets can be added to support the axle all the way up the front side to control the wrap up...
Re: Torque Monster
« Reply #9 on: November 22, 2015 - 10:56:50 PM »
I agree that weak points from a modification is why axle dropped. But that is a result of something else letting go. Look at car heaving prior to separation.
Offline 1 Wild R/T
Re: Torque Monster
« Reply #10 on: November 23, 2015 - 01:07:33 AM »
The car heaving is the drive shaft binding due to the severe pinion angle as the axle rotates....
Re: Torque Monster
« Reply #11 on: November 23, 2015 - 01:12:10 AM »
Watched the video again sure looks like the right rear is letting go first? I couldn't see if that car had any leaf springs, maybe a 4 link?  :dunno:
John Adams
Offline cudabob496
Re: Torque Monster
« Reply #12 on: November 23, 2015 - 01:20:34 AM »
don't see a drive shaft or leaf springs attached to the rearend. A single
peace of shiney metal is on the ground under the rearend.
« Last Edit: November 23, 2015 - 01:23:15 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cudabob496
Re: Torque Monster
« Reply #13 on: November 23, 2015 - 01:25:12 AM »
http://artofgears.com/2015/05/25/classic-dodge-dart-loses-rear-axle-showing-off/
saying due to hard braking
another site said the guy only owned the Dart for a couple of hrs before the event
« Last Edit: November 23, 2015 - 01:32:50 AM by cudabob496 »
2011 Kawasaki Z1000
Offline cordodge
Re: Torque Monster
« Reply #14 on: November 23, 2015 - 09:08:18 AM »
not sure but it looks like it could have been a ladder bar system and the pipe welded to the frame rails let go and the whole system came out, I think the bouncing is the body and big tires coming together? Whatever it was it would suck!!
Bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
