EFI Tank
Author Topic: EFI Tank  (Read 20598 times)
Offline 70chall440
Re: EFI Tank
« Reply #60 on: August 22, 2016 - 12:02:27 AM »
I have taken mine out of the box, however have not installed it yet in my Challenger. Looks to be a nice unit, baffled and well engineered. I did not get the biggest pump as I have a relatively stock 440. I would say my only criticism would be the inlet and outlet of the pump, they are pretty small IMO, but that isn't an issue really for me. I will adapt them to AN without issue. I didn't buy the tank pad or the strap liners as I have some rubber material I normally use.
Not sure what information you are looking for, bit IMO it is well worth what they get for it.
Current Mopar
Past Mopars
Re: EFI Tank
« Reply #61 on: August 22, 2016 - 11:50:24 AM »
Anybody have updates on how this set-up has been working out?
Great so far. I 'm too chicken to let the tank get below 1/4 tank so I don't know if "E" means empty or....?
Offline 70chall440
Re: EFI Tank
« Reply #62 on: August 22, 2016 - 11:55:51 AM »
Well, you know the tanks holds 19 gallons, next time you fill (when you are the 1/4 mark) take note of how much it takes. If it takes over 14.25 gallons, your gauge is inaccurate. You probably need to factor in how much fuel the fill tube would hold as well but you should be able to figure it out pretty easily.
Current Mopar
Past Mopars
Re: EFI Tank
« Reply #63 on: August 22, 2016 - 02:48:23 PM »
good point :2thumbs:
Offline 70chall440
Re: EFI Tank
« Reply #64 on: August 22, 2016 - 03:25:13 PM »
Here to help  :bigsmile:
Current Mopar
Past Mopars
Offline Mickm
Re: EFI Tank
« Reply #65 on: August 22, 2016 - 04:47:48 PM »
7CHALL440,
You purchased the "Tanks,inc." tank and sender huh?
Cheers!
Mickm
MickM
Offline 70chall440
Re: EFI Tank
« Reply #66 on: August 22, 2016 - 08:49:33 PM »
7CHALL440,
Cheers!
Mickm
Yes I did, for my 70 Challenger. I went a different route for my Cuda (baffled the tank myself and have an external pump)
Current Mopar
Past Mopars
Offline 70chall440
Re: EFI Tank
« Reply #67 on: August 22, 2016 - 08:51:51 PM »
Here it is
Current Mopar
Past Mopars
Re: EFI Tank
« Reply #68 on: September 02, 2016 - 12:35:56 PM »
JUst my  :2cents: but I always use JIC instead of AN , each fitting is $4 instead of $40
Offline Katfish
  • 70 Challenger
Re: EFI Tank
« Reply #69 on: September 02, 2016 - 02:39:04 PM »
JIC ?
Offline shawge
  • Zoiks!!
Re: EFI Tank
« Reply #70 on: September 02, 2016 - 03:11:34 PM »
JIC (Joint Industry Council) fittings, defined by the SAE J514 and MIL-F-18866 standards, are a type of flare fitting machined with a 37-degree flare seating surface.
- Jerry
Re: EFI Tank
« Reply #71 on: September 04, 2016 - 10:36:34 AM »
JIC (Joint Industry Council) fittings are widely used in fuel delivery and fluid power applications, especially where high pressure (up to 10,000 psi) is involved.  The SAE J514 standard replaces the MS16142 military specification, although some tooling is still listed under MS16142.  JIC fittings are dimensionally identical to AN (Army-Navy) fittings, but are produced to less exacting tolerances and are generally less costly.  JIC is typocally steel fittings
   The AN thread is a particular type of fitting used to connect flexible hoses and rigid metal tubing that carry fluid. It is a US military-derived specification that dates back to World War II and stems from a joint standard agreed upon by the Army and Navy, hence AN. Generally alum fittings
AN sizes range from -2 (dash two) to -32 in irregular steps, with each step equating to the OD (outside diameter) of the tubing in 1/16" increments. Therefore, a -8 AN size would be equal to 1/2" OD tube (8 × 1/16 = 1/2). However, this system does not specify the ID (inside diameter) of the tubing because the tube wall can vary in thickness. Each AN size also uses its own standard thread size.
AN fittings are a flare fitting, using 37° flared tubing to form a metal-metal seal. They are similar to other 37° flared fittings, such as JIC, which is their industrial variant. The two are interchangeable in theory, though this is typically not recommended due to the exacting specifications and demands of the aerospace industry. The differences between them relate to thread class and shape (how tight a fit the threads are), and the metals used.
« Last Edit: September 04, 2016 - 10:43:20 AM by Chryco Psycho »
Offline GoodysGotaCuda
Re: EFI Tank
« Reply #72 on: September 04, 2016 - 11:27:44 AM »
JIC ?
Same flare/threads as AN but typically steel and can sometimes be found locally easier. Tractor Supply.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Katfish
  • 70 Challenger
Re: EFI Tank
« Reply #73 on: September 04, 2016 - 02:43:41 PM »
That was my next question, where can we get them?
Offline msbaugh
Re: EFI Tank
« Reply #74 on: September 04, 2016 - 07:28:31 PM »
In my industry JIC fittings are even used offshore on subsea wells. Think of pressure from a 7000 foot head of water (x0.433 = 3031 psi) and other high pressure hydraulic applications.
