Author Topic: EFI Tank  (Read 20600 times)
Offline 70chall440
Re: EFI Tank
« Reply #75 on: September 04, 2016 - 07:40:09 PM »
JIC are usually readily available; think any industrial area, hose company, etc. I buy steel AN fittings from Fragola.
Current Mopar
Past Mopars
Re: EFI Tank
« Reply #76 on: September 05, 2016 - 12:57:39 PM »
I got all the fittings and PTFE line to plumb the whole car from here.
http://www.frozenboost.com/stainless-steel-teflon-fuel-lines/?osCsid=ec635fcdae645466eac1de8803bdcdf2
Offline GreenFish
Re: EFI Tank
« Reply #77 on: September 07, 2016 - 08:06:27 AM »
I tried using PTFE lines and canned the idea when i couldnt get the fittings to go on the line. I bought stuff from the link you gave a while back and I just couldn't figure it out. I dont intend on using flex fuel anyhow.
Re: EFI Tank
« Reply #78 on: September 07, 2016 - 08:12:59 AM »
I've plumbed a few cars now with it? I cut the hose square , then push on the nut, then push on the ferrel till it sticks out a little past then trim it flush. Then I take my disc grinder with a cut off wheel and trim the stainless braided part almost to the bottom of the ferrel. Then lube up the fitting and screw it on. Works easy enough for me?
Offline shawge
  • Zoiks!!
Re: EFI Tank
« Reply #79 on: September 07, 2016 - 11:08:49 AM »
 :iagree: The Frozen Boost hose works well.  Not too expensive either.  I don't have the disc grinder skills Brad has; I used tin snips to trim the braid.
- Jerry
Offline 70chall440
Re: EFI Tank
« Reply #80 on: September 12, 2016 - 12:57:53 AM »
This is what I have been using, very easy to use and looks great.
https://www.summitracing.com/parts/fra-842006/overview/
Current Mopar
Past Mopars
