Author Topic: A pair of questions on a RV-2 air conditioning compressor  (Read 1000 times)
Offline dakota
« on: November 29, 2015 - 11:03:02 PM »
I've been reassembling the RV-2 air conditioning compressor from my Challenger.   I've got 2 questions that I'm hoping one of you folks can answer:
1.  There's a small bolt (roughly in the 12 o'clock position in the attached picture) among the 5 that are used to snug down on the crank bearing and seal that I think was an attachment point for a wire.   I can't remember where the wire originated - maybe just a ground?   There's nothing on my wiring diagram.   I have to reattach whatever it is before I can put the clutch back on.
2.  Best I can tell, there's no set torque value for the 5 bolts for the crank bearing and seal.   The service manual indicates that the torque to turn the crank should be 10 inch lbs or less.   If it's too high, it appears that the 5 bolts are supposed to be loosened up a bit until the torque is below the limit.   In my case, this is just barely finger tight.   It seems too loose.   Before assembly, I wiped down the inside of the cylinders with A/C oil (PAC 100), but I haven't put anything in the sump yet.
I'm not in a big hurry to have the A/C working since, compared to when I lived in TX, Buffalo summers are pretty mild - but I do want to be able to route the fan belts through the A/C compressor pulley.  Any help would be appreciated.
Offline 1 Wild R/T
Re: A pair of questions on a RV-2 air conditioning compressor
« Reply #1 on: November 30, 2015 - 12:09:28 AM »
As far as the rotating torque, loosening the bolts allows the bearing preload to release... Either a bearing cone or cup might not be fully seated or you need to shim the front plate to increase clearance... As far as the wire it's been a lot of years but I'm thinking it's the ground for the clutch coil...
Offline dakota
« Reply #2 on: December 04, 2015 - 06:31:01 AM »
Mystery solved.   The small bolt is the mounting point for a guide on the power feed to the magnetic clutch.   There's another guide on the same wire that is supposed is held in place by one of the head bolts on the a/c compressor.   Naturally, I have already torqued the head bolts.   I'm sure this isn't the last time I will get to re-do something on this car.
