Author Topic: Starting engine on stand  (Read 1897 times)
Offline soundcontrol
« on: November 30, 2015 - 04:42:26 PM »
Got a 340 that I wanna start without installing it in the car. My buddy has a startup stand for his race engines, he dosen't have a flywheel or bell housing to mount a starter for a small block though. Now, is there any other way to start a 340 on a stand, can I mount the converter and run it loose without oil (If I can get the starter temporary mounted somehow), or mont the tranny without oil? (727)
Can I use an air wrench on the balancer nut to start it? Any other creative ways?
Handcrank it?  :grinno:
/ Ken
topic=108917.new#new
Offline roadman5312
Re: Starting engine on stand
« Reply #1 on: November 30, 2015 - 05:01:03 PM »
Manual trans flywheel, bellhousing and starter.  Don't use the impact on the balancer bolt  :nono:
 :rebel:
Offline Racer57
« Reply #2 on: November 30, 2015 - 09:44:06 PM »
You want to do this correctly and not take short cuts or you WILL pay for it later. Go to the junk yard if needed and buy a manual tranny setup.
« Reply #3 on: November 30, 2015 - 11:34:33 PM »
I would not try to use a converter on a flex plate with nothing supporting the weight of the converter on the rear I would think that could turn into a very quick lesson in physics
« Reply #4 on: December 01, 2015 - 05:56:13 AM »
OK, I was hoping for a way witout getting the manual tranny parts, but I guess I have to do that, maybe I can borrow a setup from someone. You guys are lucky with your junkyards, in Sweden all there is in those are a bunch of Volvos and Saabs!  ;)
/ Ken
Offline 1 Wild R/T
« Reply #5 on: December 01, 2015 - 11:15:45 AM »
You just need a bell housing, Mopar big/small block flywheel is the same...  Assuming both are neutral balanced...  And the same tooth count  (130 or 143)... But honestly if your able to borrow a bell housing getting the matching flywheel would be the best option...
« Reply #6 on: December 13, 2015 - 05:19:06 PM »
How about this? I got a 727.
http://vid.carbuzz.com/this-is-what-happens-when-you-rebuild-an-old-v8/?utm_source=312
Whats that thing at the end of the tranny?
/ Ken
« Reply #7 on: December 13, 2015 - 06:19:12 PM »
Parking brake , used in the 50s & early 60s & in trucks
