Author Topic: Pictures please......Wilwood Combination Proportioning Valve  (Read 4262 times)
Offline challenger_73
« on: December 02, 2015 - 09:08:06 AM »
Hey all,
Hope everyone had a great Thanksgiving. I am installing my Wilwood Combination Proportioning Valve, Part number 260-11179. If anyone has pictures of how they mounted this to the body and any modifications to the Brake Lines coming into it from the Master Cylinder and going out to the Calipers it would be appreciated. Thanks much!
challenger_73
Re: Pictures please......Wilwood Combination Proportioning Valve
« Reply #1 on: December 02, 2015 - 01:16:08 PM »
It's been awhile, but I do remember having to cut off the ends and use different connecters for the brake lines.
Hope that helps?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: December 02, 2015 - 01:27:50 PM »
here ya go!
Offline jhaag
« Reply #3 on: December 02, 2015 - 02:42:56 PM »
New lines on this one
love 70 Challengers
« Reply #4 on: December 02, 2015 - 08:43:11 PM »
Excellent. Thank you so much! Great photos.
challenger_73
Offline soundcontrol
« Reply #5 on: December 03, 2015 - 04:50:14 PM »
I ordederd the Wilwood cylinder and discs all around, but did not order that valve, do I need it?
/ Ken
topic=108917.new#new
« Reply #6 on: December 03, 2015 - 04:57:07 PM »
I'd try it first. I installed mine when I was building my car " just in case I needed it" I have never used it yet, its always been wide open.
« Reply #7 on: December 03, 2015 - 05:12:21 PM »
thanks Brad!
/ Ken
« Reply #8 on: December 04, 2015 - 09:56:50 AM »
I don't have the wilwood proportional valve, using the stock one, but I installed an adjuster for the rear brakes. Generally these cars lock up too early on the rears and the adjust-ability is a definite improvement on my car. In order to get the rears to brake properly I had to restrict the rear line pressure significantly. From Brad's response, that is not always the case I guess, so I think the adjust ability is good to have cuz every car will likely be a little different. :2cents:
« Reply #9 on: December 04, 2015 - 11:36:32 AM »
I'm guessing it depends on your brake combo? Stock rear drums did have a nasty habit of locking up before the fronts. When I had rear drums I used truck wheel cylinders to prevent this. Worked great! Now I have DrDiff's rear disc brakes and Viper calipers up front and have never needed to use the adjuster but it's there just in case.....
Offline HP_Cuda
  • Mopar or No Car!
« Reply #10 on: December 04, 2015 - 12:15:11 PM »
I have a similar experience to Brad, I've adjusted it slightly for the rears but barely.
Offline Ken D
« Last Edit: December 06, 2015 - 09:49:10 AM by Ken D »
1970 Plymouth Barracuda Pro-Touring
« Reply #12 on: December 05, 2015 - 12:36:57 PM »
That looks great!
/ Ken
« Reply #13 on: December 06, 2015 - 07:06:17 AM »
« Reply #14 on: December 06, 2015 - 07:06:48 AM »
Do you have stock rear brakes HP? If you do I'm thinking maybe the stock proportioning valve is the source of the problem (excessive rear braking force) for me.
