Author Topic: Intake gasket install  (Read 1407 times)
Offline soundcontrol
« on: December 02, 2015 - 02:40:40 PM »
The Feel Pro blue intake gaskets, should I NOT use any sealer on theese? I read in the instructions that not to use sealer on fiber faced gaskets, are theese fiber faced? (if so, not even around the water channels?) I will use the Permatex on the cork end gaskets and some silicone on the ends where the cork gaskets meets the blue gasket.
/ Ken
topic=108917.new#new
Offline cudabob496
Re: Intake gasket install
« Reply #1 on: December 02, 2015 - 03:45:56 PM »
water channels on intake?
is this a 440?
if you put on the intake to the heads, without the gaskets, and you see no significant gaps, then
you will probably be ok without sealant. But sealant can't hurt, and I have used it.
2011 Kawasaki Z1000
« Reply #2 on: December 02, 2015 - 04:02:23 PM »
It's a 340, it says to install fiber faced gaskets dry, and I don't know if that blue one is a fiber faced gasket...
Got no gaps, intake fits well.
/ Ken
Offline Oldschool
  • Member Since 9-05-06
« Reply #3 on: December 02, 2015 - 04:25:54 PM »
I would spray a light coat of "Copper Coat" on both sides of the gasket and wait a few minutes for it to get a little tacky and put it together.... :2cents:
Ken  --  In Georgia
Offline GreenFish
« Reply #4 on: December 03, 2015 - 12:20:02 PM »
I'm a fan of the copper spray as well
Offline Mopar Mitch
« Reply #5 on: December 03, 2015 - 01:35:13 PM »
ALL -- I was an engineer with Fel-Pro from 1976-1998 (later, Federal-Mogul bought out Fel-Pro...)... I WROTE THOSE and all INSTRUCTIONS.  The fiber face and raised embossed ridges do the sealing... NO CHEMICALS REQ'D!... just a dab of RTV at the 4-corner joints.  FORGET THE COPPER SPRAY.
« Reply #6 on: December 03, 2015 - 03:30:08 PM »
Yep, Mitch is right, I also posted the question on the Fel-pro forum last night, got an answer in 3 hrs. Great support they have!
Some gaskets are good with sealer, not theese blue ones though.
"Hi Ken,Don't use any sealer along the intake manifold gaskets or around the ports. A dab of RTV at each corner where the ends seals meet the intake gaskets is all that's needed. You can use high tack or brush tack to hod the cork end seals in place, but don't apply more than what's needed to hold them in place. We hope this helps! "
/ Ken
Offline TelisSE440
« Reply #7 on: December 04, 2015 - 06:02:19 PM »
That's how i installed my Fel Pro instake gaskets (440 engine) just a little RTV in the corners, no leak in two years...
« Reply #8 on: December 05, 2015 - 07:20:48 AM »
Bigblocks are way better, no waterchannels in the intake and the intake don't seal the lifter valley. This is the first time I put a small block together.
...and last, I hope  :grinno:
/ Ken
