Author Topic: Just want to make sure - no coolant question  (Read 2169 times)
Offline CUDA JAS
  • vroooooom!
« on: December 03, 2015 - 11:23:34 AM »
I don't see how this would cause a problem, but, any issue with draining the majority of the coolant out on the engine for the winter.
I want to repaint my rad and ditch my headers this winter, and obviously I need to drain the coolant to do either of these.
Is there any reason to think this would cause a problem during the impending long cold winter?? :canada:
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline 1 Wild R/T
Re: Just want to make sure - no coolant question
« Reply #1 on: December 03, 2015 - 11:28:28 AM »
The only issue is the water pump seal may dry out & leak in the spring...
Offline AARuFAST
  • AARuFAST
« Reply #2 on: December 03, 2015 - 08:15:43 PM »
Paint rad in a day or two reinstall it couple days later no problem. But if u leave it off over a month you can plug the bottom hose install exhaust manifold bolts into heads and keep anti-freeze in the engine.
Do not flush anti-freeze and leave only water in engine if you live in
area going below freezing.
« Last Edit: December 03, 2015 - 08:27:44 PM by AARuFAST »
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline TelisSE440
« Reply #3 on: December 04, 2015 - 05:45:50 PM »
:iagree: You can do your job quick and reinstall, no problem...
Offline CUDA JAS
  • vroooooom!
« Reply #4 on: December 11, 2015 - 03:58:43 PM »
Given the weather, getting colder, I am not sure I can paint it until the spring.
I think I will just leave it for now.  My main project will be rebuilding the steering box and luckily I have a spare, so I can strat on that for now.
Then I can do the rad (which is starting to rust) and manifolds when things warm back up.
Jason
74 'cuda 360/727
Offline roadman5312
« Reply #5 on: December 11, 2015 - 04:31:13 PM »
                   :thinkerg:    Jason, listen. Inside the house is warm, right. ?  Ok, put some cardboard on the bed and paint the radiator there. Tear down the steering box on the kitchen table, then put all the parts in the dishwasher for cleaning.    :2thumbs:
You will be ready to go come spring.   :2thumbs:    I mean your a single guy right.   :clueless:  Well if not single, then you might be dead.   :faint:   :misbehaving:   Just tryin to help.    :roflsmiley:                 :rebel:
Offline CUDA JAS
  • vroooooom!
« Reply #6 on: December 11, 2015 - 07:10:05 PM »
Well I will be single after trying any of the above!!! :stomp: :stomp: :stomp:
I don't mind working out in the cold...so I will just pick away at things over the winter.
Jason
74 'cuda 360/727
Offline anlauto
« Reply #7 on: December 11, 2015 - 07:34:00 PM »
Nothing Jason does ends up being a "quick job"... :roflsmiley:
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: December 12, 2015 - 10:58:08 PM »
There is a lot of truth in that statement.
 :bigsmile:   :dunno:  :clueless:  :pullinghair:
74 'cuda 360/727
