I screwed the fan thermoswitch there (Be Cool unit - 195 on, 175 off) and i blocked the other port. I turned over the engine and i waited for the fans to turn on. I waited long enough until i saw the temp gauge (stock non Rally Gauge) reach 3/4 and then, afraid of overheating the engine, i shut it off and manually engaged the fans. I reversed the sensors (fan to the pump port and temp to the neck port) and the fans came on (195 F) while the radiator was still cool. Needless to say, the fans never came off (even when temp gauge needle was on Cold!) only until i turned off the engine and waited about 10 minutes. My question is if it is right to install both sensors at the water neck (as in pic), because i think that the coolant temperature is extremely high in the left of the electric pump and i'm not getting acurate readings. Thanks in advance guys...
