Author Topic: Help with small block oil pump driveshaft  (Read 975 times)
Offline soundcontrol
« on: December 05, 2015 - 04:37:47 PM »
Darn smallblocks, I have no experience with them. Is the driveshaft to the oilpump supposed to be this loose? (se video link) or am I missing a bushing or something? The driveshaft in a big block does wiggle like this. Picture of the hole without the shaft.
https://youtu.be/Dqz_nrp-hjU
/ Ken
topic=108917.new#new
Offline blown motor
Re: Help with small block oil pump driveshaft
« Reply #1 on: December 05, 2015 - 05:17:20 PM »
Wow! That doesn't look right.
« Reply #2 on: December 05, 2015 - 05:19:34 PM »
I'm almost sure there should be a bronze bushing there, as on the bigblocks, never put a smallblock together before, so I figure I'll better ask...
/ Ken
« Reply #3 on: December 05, 2015 - 05:58:03 PM »
 :iagree:  there should be...same part even..
http://www.summitracing.com/parts/dcc-1737725/overview/
« Reply #4 on: December 05, 2015 - 06:06:06 PM »
Ah, thanks, machine shop must have took it out when they did the block. I'm glad I noticed, would not have been to cool trying to start without it!
/ Ken
Offline moper
« Reply #5 on: December 11, 2015 - 12:24:11 PM »
Small and big blocks use the same bushing. I believe it is Pioneer brand that is made to be installed and run, vs the factory & MP type that gets installed and then needs to be burnished to the correct size using the right tool.
« Reply #6 on: December 11, 2015 - 01:54:17 PM »
I got one, must have been a Pioneer then, it fit fine on the shaft and I installed it with no problems.
/ Ken
