Author Topic: Timing chain inspection on 70 383  (Read 1684 times)
Offline Yellow Submarine
« on: December 05, 2015 - 09:43:37 PM »
In the process of working through some issues on my 70 Challenger engine, I need to check for correct cam timing chain as it may be off. My question is, is it necessary to remove the oil pan and gasket when removing the front engine cover. The engine is still in the car and photos I have looked up make it look like I need to do this. Is the case and is there a way around it?
Thanks
70' RT SE 383 Challenger
Factory Five MkIII Roadster (Cobra)
66' Mustang FB (GT 350 Clone)
70' Kawasaki 500 Mach III (H1)
Offline mopar jack
Re: Timing chain inspection on 70 383
« Reply #1 on: December 05, 2015 - 10:42:53 PM »
You don't have to pull the pan but  you will need a gasket used to replace the timing cover. It should come in a gasket kit for the timing cover.
« Reply #2 on: December 05, 2015 - 11:04:49 PM »
Thanks MJ, a front cover gasket includes the part over the tip of the pan then?
Offline 73440
« Reply #3 on: December 05, 2015 - 11:16:17 PM »
Looks like this set has it included.
http://skspeed.com/felpro-tcs124602-timing-cover-gasket-set-mopar-361-383-400-413-440-big-block/
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #4 on: December 05, 2015 - 11:22:28 PM »
Excellent, thanks guys.
John
Offline moper
« Reply #5 on: December 07, 2015 - 11:39:04 AM »
You do know if you need to check for chain stretch you don't have to pull the cover - right? Or is there another problem you're chasing?
« Reply #6 on: December 07, 2015 - 04:28:25 PM »
Hi Moper, the issue is related to my other posts on low compression. Was going to check for correct indexing of cam to crank. Problem is likely low CR pistons.
Thanks
