Author Topic: A833 Questions on Wear  (Read 4003 times)
Offline Brillo1974
« on: December 06, 2015 - 10:47:39 PM »
In and earlier thread I posted about swapping to a 4 speed from my 727. I have a line on a 247 close ratio 833 that I might be able to purchase cheap.  What I'm looking for is how to tell if the trans is worn or other problems I can look for with the side cover off. Also can you tell much just by shifting it to see if it is smooth? Maybe someone has some pics of one with problems so I have something to compare it with? This could save me some big bucks on my conversion if it's a good trans.  Thanks
Trump.... The Voice of the AMERICAN People!
Offline 73440
Re: A833 Questions on Wear
« Reply #1 on: December 06, 2015 - 11:01:15 PM »
http://www.forabodiesonly.com/mopar/showthread.php?t=166041
Seeing as they are doing a rebuild , if parts look like this should be ok.
Spinning the shafts should be smooth, no chips in gears,
From Hemmings article below:Take the side cover off the unit you have found and check the play on the countershaft carefully; this is a good indication of how good a unit you have located. Most rebuilders would recommend that you install a bushing on the countershaft if any repairs need to be made. Aftermarket four-speed conversion humps for Chrysler cars are available for about $140 to help you complete this changeover.
http://www.hemmings.com/mus/stories/2005/03/01/hmn_feature17.html
« Last Edit: December 06, 2015 - 11:06:38 PM by 73440 »
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Finoke
« Reply #2 on: December 06, 2015 - 11:06:45 PM »
front input shaft will always have a little play so not to worry if you feel it.
Offline 73440
« Reply #3 on: December 06, 2015 - 11:09:38 PM »
Is it an 18 or 23 spline you are looking at?
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Brillo1974
« Reply #4 on: December 07, 2015 - 06:33:03 AM »
It's a 23 spline, if it would have been a 18 I would have already have bought it and took my chances for the money.  :grinyes:
Offline Brillo1974
« Reply #5 on: December 07, 2015 - 06:36:57 AM »
You talking end play or side play... I figure you are talking end play?
Offline Finoke
« Reply #6 on: December 07, 2015 - 07:14:00 AM »
Side to side
Offline Brillo1974
« Reply #7 on: December 07, 2015 - 07:37:33 AM »
Side to side
OK thanks for the info it's appreciated.
« Reply #8 on: December 07, 2015 - 07:41:10 AM »
side to side is OK , end play should be zero
 look for chipped teeth on the gears where the syncro collars lock on to the gears
check for wear on the shift forks too
 It should shift smoothly when the input shaft is being rotated but not when it it is not rotated
 Check for end play on the counter shaft too there should be very little play there .
Offline Brillo1974
« Reply #9 on: December 07, 2015 - 08:50:50 AM »
Thanks for the info guys, I will let you know what I find out.  :thumbsup:
Offline Brillo1974
« Reply #10 on: December 07, 2015 - 08:41:57 PM »
Well I went and looked at the trans tonight and it looked really good. I checked the input shaft, there is no end play in and out but it has about 3/32 side to side play at the very tip. I checked all the gears and synchronizers for wear and I can't see any at all whatsoever. Turning the input shaft while shifting it is smooth as silk. What is nice is it still has the Hurst shifter mechanism (no wear here either) as well as the operating lever set just no linkage rods. I think I stole it for $300 since just the shifter mechanism alone from Brewers is $200 and the operating levers are another $57 also I won't have to pay the high shipping costs on the trans. I pretty happy that I may be able to do my 4 speed conversion for maybe half price at this rate.  :ylsuper: :cheers:
Offline Finoke
« Reply #11 on: December 07, 2015 - 09:04:23 PM »
Nice job! 3/32 input shaft play is normal. Trans install is easy. I would try  it out as is and tHen pull it if it has an issue! Good luck!
Offline Brillo1974
« Reply #12 on: December 07, 2015 - 09:15:53 PM »
Just one other question for now under the serial number is the date it was built PP83 4912 or possibly 4812 can anyone decipher the date for me.....I cant figure out the 10,000 day calendar thing.  :clueless:
Offline 73440
« Reply #13 on: December 08, 2015 - 12:52:03 AM »
4812= Sept 30, 1974.
4912= Jan 08, 1975.
If my math is correct.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Brillo1974
« Reply #14 on: December 08, 2015 - 08:52:37 AM »
Thanks man I appreciate it!
