Author Topic: Caltrac's fitment question  (Read 3509 times)
Offline crash340
« on: December 07, 2015 - 04:45:39 AM »
So, team, I have a set of Dr Diff 1'' spring relocation hangers on a b Body diff housing in my 73 Cuda, has anyone fitted Caltracs or similar onto factory style offset hangers and so on, looks to be a big task to me.
Greg
73 Cuda
Brisbane, Australia
Re: Caltrac's fitment question
« Reply #1 on: December 07, 2015 - 07:33:32 AM »
My experience with Caltracs was zero gain so why bother ?
Offline HP_Cuda
  • Mopar or No Car!
« Reply #2 on: December 07, 2015 - 01:27:27 PM »
The way Caltracs are setup I don't think you could use offset hangers, I guess you could try but it would be a PITA.
Offline rUNCHARGER
« Reply #3 on: December 07, 2015 - 01:33:10 PM »
They didn't help Chryco? I was going to order a set for my car and a friend's car. Good to know.
Sheldon
Offline crash340
« Reply #4 on: December 07, 2015 - 02:12:42 PM »
Thanks guys, I was thinking fitment would be a pita for sure, Im going to add another leaf to my spring pack to take them to 5 1/2 leaves, might just see how they go and take it from there.
Greg
73 Cuda
Brisbane, Australia
« Reply #5 on: December 07, 2015 - 09:13:15 PM »
we installed them on a 440 duster it ran 11.8 with a 1.7 60 ' before we installed the caltracs & it ran 11.8 with a 1.7 60' after the Caltracs even after numerous adjustments
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #6 on: November 14, 2016 - 12:25:25 AM »
With or without SS Leaf Springs or Pinion Snubber?
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
« Reply #7 on: November 14, 2016 - 10:08:47 AM »
Since Cal-tracs mount in the spring eye/hanger and under the housing u-bolts, I don't see where fitting them on an inboard set up would be any different than a stock set up.
Offline onebadfish
« Reply #8 on: November 14, 2016 - 12:30:48 PM »
Yep what he said....
Offline crash340
« Reply #9 on: November 14, 2016 - 04:48:21 PM »
Thanks guys, I've determined fitment won't be an issue, I now have to work through all the various options pro's and cons, caltracs, clamps, extra leafs, bolt on front segments only, snubbers and on and on
Greg
73 Cuda
Brisbane, Australia
« Reply #10 on: November 15, 2016 - 10:06:55 AM »
Based on this I take it you have the original 318 4/5 leaf pack with 40 years of use on them. Nearly anything will be a step up. How are you using the car, what type of power are you pushing and what wheel and tire combo is on it?
Offline vinb
« Reply #11 on: November 15, 2016 - 09:37:46 PM »
Cal-Trac's can't be that bad, just about every NHRA stock eliminator car and a lot of bracket cars use them, but you do need the hold package for them to work.
For the street make a custom pair of leaf springs and a snubber will work well.
 :thumbsup:
Offline crash340
« Reply #12 on: November 15, 2016 - 11:27:41 PM »
It's a steet cruiser, original 340 springs that are actually in very good order and have been fully rebuilt. Adding an extra leaf is no issue. Power will be a 600hp 408 (flywheel). Through a 727. The Dana is from a truck donor so no snubber mount. Yes I could screw one to the floor but I don't want to, I can make a snubber bracket for the D60 as an option.
Greg
73 Cuda
Brisbane, Australia
Offline vinb
« Reply #13 on: November 17, 2016 - 09:21:06 PM »
Greg ,
If you use your 340 springs, clamp the hell out of the front segments maybe 5 or 6 clamps both sides..
I use a B-Body housing and B-body springs that I modified from a six pac car..
Worked pretty good for me
60 ft were  1.54 to 1.56 avg in a 3680 lb 340 NHRA Stocker Cuda wth a auto transmission back in the 80's.
Offline crash340
« Reply #14 on: November 17, 2016 - 09:50:46 PM »
Thanks VINB,
I really need to sit down and think through the pro's and con's of options. Appreciate the feesback
Greg
73 Cuda
Brisbane, Australia
