Author Topic: 71 Barracuda East Coast  (Read 1370 times)
Offline nicka
« on: December 09, 2015 - 08:55:56 PM »
I was able to locate two broadcast sheets. One was under the front bucket seat. The other was under the back seat. The back seat is readable.
I'm going thru the numbers.  Got most of them.  Some I have questions on these four sections:
Basic Car2:
Trim Code: H6F7
Build3:
UDF: 000
Steering Column: 255X97000
Steering Wheel: 69X9
Horn Pad: 82X9
Rad: 71
Inlet Hose: 02
Alt: 78
Fan: 50
Fan Spa: 56
Bat: 51
Code4:
Vac fit: 92
Code5:
Torsion Bar:Lt 779 Rt: 778
Rear Springs LT: 44 RT: 44
Clutch Brake Pedal: 47?0    Cant read out the third number
Labels Vec: 27  Tire: 18
Exhaust: LT: 00 RT: 62
Tail Pipe: Lt: 00 RT: 66
Front Brake: LT: 67  RT:66
Thanks,
nicka
Offline nicka
Re: 71 Barracuda East Coast
« Reply #1 on: December 10, 2015 - 06:05:01 PM »
Looks like some of these codes are related to part numbers?
I think I got the steering column.  Power Steering 727 Black.  That sounds right.  This is an auto 727.
Offline anlauto
« Reply #2 on: December 10, 2015 - 07:21:59 PM »
All that stuff is last two digits of a part number Like Inlet hose 02 means 3462102 etc...
You need Galen Govier's little white book to figure out all the part numbers.
Offline nicka
« Reply #3 on: December 11, 2015 - 08:34:44 AM »
Cool. Thanks
