Author Topic: who has espo leafs +1 and +2  (Read 14786 times)
Offline Rafilla
Re: who has espo leafs +1 and +2
« Reply #45 on: October 11, 2016 - 06:51:02 AM »
Hello to all,
Im going to order a new leaf springs from ESPO and I cannt decide the height, (stock, +1, +2...)
now I have 4 wheels 235/60R15 (15x7) but in near future I'll install 15x8 rally wheels with 275/60R15 on rear:
with Chrysler wheels measures:
https://www.summitracing.com/int/parts/usw-667-5812
can you help me to decide the height without rubbing please?
thanks and best regards
1970 Dodge Challenger
Green Go
440
4spd
Offline KillerBee
« Reply #46 on: October 11, 2016 - 02:31:36 PM »
Hello to all,
If you use 4 1/2" back spacing on a 15x8 wheel 275/60-15 tires fit on the back of a Challenger with no problem.
I also have the same 15x8 wheel with 4 1/2" back spacing on the front with 245/60-15 tires, no rubbing there either.
« Last Edit: October 11, 2016 - 07:38:53 PM by KillerBee »
Offline Rafilla
« Reply #47 on: October 13, 2016 - 09:26:36 AM »
Thank you KillerBee
And without spacer its possible??
Green Go
440
4spd
Offline KillerBee
« Reply #48 on: October 13, 2016 - 06:53:23 PM »
No wheel spacers on my Challenger, front or rear.
Rear end is stock Challenger width.
The 4 1/2" back spacing is critical when using a 15x8 wheel.
Offline Rafilla
« Reply #49 on: October 20, 2016 - 02:27:53 AM »
Thank you!!!
Well what Espo height can I choose? Help me to decide please
Thanks and best regards
Green Go
440
4spd
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #50 on: October 20, 2016 - 12:37:41 PM »
Thank you!!!
I would order 440/Hemi springs +1" from espo.com with all new hardware and shackles if needed.
Offline KillerBee
« Reply #51 on: October 24, 2016 - 06:38:30 PM »
These are ESPO +1.5 that I just installed on my wife's R/T Challenger.
Springs were installed with a 1967 B body rear end with Dr. Diff's offset hanger kit.
Tires are 275/60-15.
Car currently has no drivetrain installed so it's sitting a little high in the front.
Offline Rafilla
« Reply #52 on: October 25, 2016 - 11:33:20 AM »
thanks dfrazz
thanks KillerBee the +1.5 looks very very good
Excuse me but what is "1967 B body rear end with Dr. Diff's offset hanger kit."??
Green Go
440
4spd
Offline Rafilla
« Reply #53 on: October 25, 2016 - 11:55:02 AM »
other question, with ESPO +1.5 can I install the kayaba shock absorber KG5512?? or I need other with more length??
Thanks!!!
Green Go
440
4spd
Offline KillerBee
« Reply #54 on: October 25, 2016 - 03:23:37 PM »
thanks dfrazz
The rear end from Mopar's 1966-1967 and 1968-1969 B body cars are narrower than your Challenger.
You can easily install a B body rear end in your (E body) Challenger by using Dr. Diff's offset leaf spring hanger kit.
The narrower B body rear end installed will allow you to fit wider rims and bigger tires under the rear of your Challenger without cutting or doing major modifications.
Do some searching here and on the internet for Dr. Diff, offset spring hangers, B body rear end, etc.
« Last Edit: October 25, 2016 - 03:25:49 PM by KillerBee »
« Reply #55 on: October 25, 2016 - 05:50:46 PM »
Offsetting the springs from their stock location to a position closer to the middle of the car allows you to install wider wheels/tires without modifying the wheel wells. In stock form, the leaf springs on an E body are positioned so that they are wider than the wheel wells so they limit how wide a tire you can use. Moving them in removes this restriction. Using the Dr Diff 1" kit  with a 66-69 B body rear housing allows you to bolt it all together with no welding.  You can move the springs in and use the original E body housing and achieve the same width wheel/tire as the B body housing conversion, but it then requires welding on new axle housing perches to align with the new spring location.
Offline Rafilla
« Reply #56 on: October 26, 2016 - 02:11:17 AM »
Thanks to KillerBee and HP2 for the axle education. This is a mod for the future!!
Green Go
440
4spd
Offline KillerBee
« Reply #57 on: October 26, 2016 - 05:24:05 AM »
I installed stock length Monroe shocks on the wife's Challenger, they fit fine.
Offline Rafilla
« Reply #58 on: October 26, 2016 - 09:20:13 AM »
Thanks again KillerBee is appreciated your help!!!
Your wife's car looks very very good enjoy it
Green Go
440
4spd
Offline Rafilla
« Reply #59 on: November 02, 2016 - 11:59:15 AM »
ordered ESPO +1  :cheers:
Green Go
440
4spd
