Author Topic: Need a dash panel...stainless, alloy.....where to get?  (Read 5960 times)
Offline Plum Crazy 71
« on: December 10, 2015 - 10:15:52 PM »
Hey,
I need to replace my non ralley dash panel with a custom version.
Any good tips as far as where to find a good looking custom dash.....like this maybe.
Offline GreenFish
Re: Need a dash panel...stainless, alloy.....where to get?
« Reply #1 on: December 11, 2015 - 11:49:05 AM »
This one is ok, if you are going that route. I wish the Tach and speedo were next to each other
http://classicdash.com/product/1970-74-challengercuda-6-gauge-panel-with-auto-meter-gauges/
Offline Mpdlawdog
« Reply #2 on: December 11, 2015 - 02:47:16 PM »
same here...Id already have that in my car if it did... :popcorn:
Offline WildJones
« Reply #3 on: December 11, 2015 - 03:28:04 PM »
I agree too. I am having a local machinist make something out of 6061 for me. Similar to the Ralleye Dash, but slightly different. Hoping it turns out nice and fits in the car the first go around (yeah right).
95682
1970 Cuda
« Reply #4 on: December 12, 2015 - 04:31:56 PM »
They even show them together in the pic behind the ad...lol.
Offline GreenFish
« Reply #5 on: December 15, 2015 - 10:37:01 AM »
No idea why they did that. The Ebody dash is the only one like that too. On one hand I can see it more "racecar" like where you have the tach right in the middle and the speedo off to the side. But I'm all about how it looks and a big tach and speedo right next to each other centered on the steering wheel just looks right.
Offline Devil
  • Forward, Together Forward
    • Ryan's Cars in Barns
« Reply #6 on: December 20, 2015 - 05:05:28 PM »
My friend made a plate, and I did the rest.  Pretty simple to do.
Ryan
http://www.flickr.com/photos/hemipwr70/
http://carsinbarns.blogspot.com
71 Challenger R/T Clone
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
88 Caprice Classic Brougham
Offline GreenFish
« Reply #7 on: December 20, 2015 - 08:12:44 PM »
Ryan
I like that too, but I want my tach and speedo both to be large diameter
Offline Mpdlawdog
« Reply #8 on: December 21, 2015 - 11:39:02 AM »
Hey,
MAN I love the look of that!  That would be perfect for what I am doing to my car....wish I had the skills to make it!  I like that Devil..just both the tach and speedo in the same cluster....your friend does good work! You should see if he can make them like this...sounds like he might have a few customers already :bigsmile:
« Last Edit: December 21, 2015 - 11:40:38 AM by Mpdlawdog »
Offline Devil
« Reply #9 on: December 21, 2015 - 01:52:01 PM »
It would be nice, except it is just a front plate.  The backing is still the original standard gauge cluster, modified.  But I guess if you use a Rallye Gauge cluster backing, and use the plate as the front, it should work.
Ryan
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
Offline Mpdlawdog
« Reply #10 on: December 21, 2015 - 05:13:27 PM »
Ryan
Interesting...using a rally gauge dash would really limit your gauge selection....since there is only 4 holes....
Offline Devil
« Reply #11 on: December 21, 2015 - 07:16:28 PM »
Get a junk rallye gauge cluster housing, cut it up.  All you need is some support for plate to mount too.
Ryan
69 Charger R/T SE
70 Barracuda
74 Dart Swinger
93 RamCharger
Offline YellowThumper
  • I left the snow for this?
« Reply #12 on: December 21, 2015 - 11:07:29 PM »
Rallye dash doesn't have the single large pod like the standard one does. It is an even slate all the way across the bottom.
Here is one I am slowly making. Same curve as factory piece but will house the full complement of gauges. With speedo and tach being the larger diameters in the middle as several have mentioned for their preference.
« Last Edit: December 21, 2015 - 11:23:32 PM by YellowThumper »
Offline Mpdlawdog
« Reply #13 on: December 22, 2015 - 06:51:47 AM »
NICE WORK!   That's what I'm talking about!  Are the gauges going in the stock location using the old rally backing or is that a stand alone bolt in piece meaning you can put the gauges anywhere??
Offline GreenFish
« Reply #14 on: December 22, 2015 - 08:11:42 AM »
I like it Mike!  Plan to sell any ?
