Power Steering Box Rebuild --All Done
Author Topic: Power Steering Box Rebuild --All Done  (Read 32530 times)
Offline CUDA JAS
  • vroooooom!
Re: Power Steering Box Rebuild --- CRAP!!!!
« Reply #75 on: March 01, 2016 - 09:48:05 AM »
The outside scale is lbs. Are you sure you read the wrong scale?
Yep...I was focused on the big numbers!!!
74 'cuda 360/727
Just call me a gearhead!
Offline YellowThumper
  • I left the snow for this?
« Reply #76 on: March 01, 2016 - 05:14:51 PM »
Aren't the big numbers what we all focus on?  :smilielol:
Sorry.
Hope it sorts out well with the re-do. My project would be done years ago if I only had to do them once.
Keep plugging we appreciate your detailing thus far.
Offline roadman5312
« Reply #77 on: March 01, 2016 - 06:26:04 PM »
             I HATE METRIC. I wish who ever thought we needed it would shove it where the sun don't shine.  :pullinghair:    :banghead:       :rebel: :rebel:
Offline CUDA JAS
  • vroooooom!
« Reply #78 on: March 01, 2016 - 09:51:48 PM »
Sorry.
LOL!!  so true.
I was out in the garage and fixed it.  I had not trouble re-staking the nut.
I feel much better about it now.
Tomorrow its on to bearing install in the box.
Jason
74 'cuda 360/727
Offline anlauto
« Reply #79 on: March 01, 2016 - 09:53:47 PM »
You know you can buy a rebuilt one at NAPA :poopoke:
Offline CUDA JAS
  • vroooooom!
« Reply #80 on: March 01, 2016 - 10:11:22 PM »
Yep...what fun would that be.
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
Re: Power Steering Box Rebuild -- Complete Well Almost
« Reply #81 on: March 04, 2016 - 08:52:51 PM »
Ok guys...I am almost done.
The box is all back together and I think I am in good shape...I admittedly did not take as may pics of assembly, but I found the disassembly was the important part.
Here are the few pics I did take...
Assembled Power Unit:
New Bearings in the box and seals in the box:
Don't forget the washer under the snap ring, although its an easy fix.
Grease seal.  you can see the second bearing deep down there:
Assembled box:
and yes my small messy workbench...seems to always wend up messy while I am on a project.
I have the return hose assemble left to clean up and install on the box and of course paint the assembled unit.  I thought about painting it while it was apart, but then realized I would destroy it as I assembled it.
Next post, I will offer some assembly tips, tricks, thoughts and opinions...for what ever they are worth.
Jason
74 'cuda 360/727
Re: Power Steering Box Rebuild --All Done well almost.
« Reply #82 on: March 04, 2016 - 10:05:28 PM »
I'm curious how much time and costs you have into it?
It'll be interesting to hear your feedback on it once you drive it.
« Reply #83 on: March 04, 2016 - 10:13:54 PM »
Good for you Jason!  :ylsuper:
Offline jimynick
« Reply #84 on: March 04, 2016 - 10:38:11 PM »
'At a boy, Jason! Coming along and can't wait to hear how it worked out!  :thumbsup:
Offline CUDA JAS
  • vroooooom!
« Reply #85 on: March 05, 2016 - 08:54:13 AM »
Ok here we go…my tips trick etc on rebuilding a steering box…first and foremost, patience…I had to redo a few things because I rushed a few things on reassembly.  I tend to get a little excited when I am putting things back together…so I always need to remind myself to slow down and read the dame FSM or other instructions while I am working.
Next…take pics while you are dissembling everything…I found a few spots where the pics were very helpful.  There is a washer under the snap ring on the pitman arm end of the cross shaft that is not shown in the exploded view in the FSM.  I went back and noticed this in my pics and was able to put the washer in.
When you are assembling the power unit, the race (the this piece with the slot in it pictured below) has a hole in one side.
The spacer below that fist over the race, also has a hole in it:
Oh you guessed it…those two holes need to be aligned.  Seems simple right, but I missed this while I was test assembling my spare box…and it is a pain to get the power unit back out once it is installed.
On that topic, the holes in the spacer are important and need to be aligned with the hole in the top of the box…when you install the power unit, the teeth also need be aligned in the cross shaft bore.…I had the hole in spacer off more than I would like to admit.  Like I said it is a pain to get the unit back out.  It is possible to move the spacer by tapping the head of the power unit to align the holes, but it is a pain. I figure this was the lesser of the two evils.
Installing the power unit is somewhat of a pain because it is a tight fit and all the weight is at bottom.  I found I had to give the cover a few whacks with the handle of my hammer to get it down into place, but it will go.
As I said above, make sure you take lots of pics and read the step by step instructions in the FSM, there are few steps that are important and a bit of a pain to go back and re do.
When you first pull it apart it is a little intimidating, but once you see how it all comes apart it starts to make sense and goes back together fairly easy.
All in all I have it back together and everything spins nice and freely, So I am very hopeful it will work well.
I still need to figure out a way to torque the two spanner nuts...but I am sure I will figure that out.
If anyone has any questions on doing this themselves I am happy to offer whatever help I can.
Jason
74 'cuda 360/727
Offline CUDA JAS
  • vroooooom!
« Reply #86 on: March 05, 2016 - 09:02:20 AM »
That is a good question...cost less than $50 for the rebuild kit form Rock Auto. You will need to rent a pilot bearing tool and slide hammer for the bearings.  Rental for me was free.
Time is harder, I was not really keeping track.  I can unusually find about an hour a night to work in the garage. I would say I needed a few hours to disassemble everything.  An hour to clean everything. A few hours to reassembly everything.
If you did it all at one time, I would bet you could have this doing in a day, a weekend tops, outside of painting and drying time once the box is assembled.
Oh wait, maybe an extra day pull the box out and put it back in.  Depending on if you have headers or not, that can be a bit of a pain.
Jason
74 'cuda 360/727
Offline 73440
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Salty Dog
« Reply #88 on: March 05, 2016 - 09:26:40 PM »
Any tips on how to get the unit out of the car?
Mine is a 70 383 car with headers
Offline CUDA JAS
  • vroooooom!
« Reply #89 on: March 06, 2016 - 11:22:12 AM »
Are you adding the coupler clamp?
http://www.rosevillemoparts.com/images/products/steeringcouplerclamp-9294.jpg
No plans to.  I have not had any issue with the stock style retainer.
Jason
74 'cuda 360/727
