Author Topic: Power Steering Box Rebuild --All Done  (Read 32469 times)
Offline CUDA JAS
  • vroooooom!
Re: Power Steering Box Rebuild --All Done well almost.
« Reply #90 on: March 06, 2016 - 11:38:47 AM »
Any tips on how to get the unit out of the car?
Mine is a 70 383 car with headers
Yep...take the header off, let it hang down. Drop the starter and the box should drop out.
That's what I had to do on my small block.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline 1 Wild R/T
« Reply #91 on: March 06, 2016 - 02:01:01 PM »
No plans to.  I have not had any issue with the stock style retainer.
Jason
 :iagree: I've installed easily 50+ & haven't had any problem with one in many years... At first I did till I developed a method that works for me...
Offline Salty Dog
« Reply #92 on: March 06, 2016 - 07:19:01 PM »
My 70 is leaking out of the top shaft. Would tightening the big castle type nut help any?
Offline CUDA JAS
  • vroooooom!
« Reply #93 on: March 06, 2016 - 08:12:09 PM »
You mean where the steering shaft connects or the adjustment on the cross shaft??
Jason
74 'cuda 360/727
Offline Salty Dog
« Reply #94 on: March 07, 2016 - 06:20:10 PM »
From the steering shaft
Offline CUDA JAS
  • vroooooom!
« Reply #95 on: March 08, 2016 - 08:57:39 AM »
If it is loose and leaking from the O-ring in the power unit head...tightening it may help.  If it is leaking from the seal around the input shaft tightening it will not help.
Jason
74 'cuda 360/727
Offline 1 Wild R/T
« Reply #96 on: March 08, 2016 - 11:37:16 AM »
However that rear seal can be replaced with the steering box still in the car, just gotta pull the column, I use a sharp punch to make a small hole in the metal face of the seal, then use a long  #4 sheet metal screw, put it in a couple threads then grab it with some wire cutters & lever the seal out.... New one is installed using a piece of PVC pipe as a driver...
Offline Salty Dog
« Reply #97 on: March 08, 2016 - 07:09:40 PM »
That might be the way to go!
Does anyone have the page that shows the breakdown of the seal?
Offline 73440
« Reply #98 on: March 08, 2016 - 08:44:14 PM »
All your manuals are here.
Section 19
http://www.mymopar.com/index.php?pid=109
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Salty Dog
« Reply #99 on: March 09, 2016 - 06:35:12 AM »
Section 19
Thanks
I can't get them in my iPad but I'll find someone to print it for me. Until then do you know the part number for the seal so I can try and see what it looks like?
Offline 73440
« Reply #100 on: March 09, 2016 - 08:50:43 AM »
PS section starts on page 576.
I see three seals listed in 1970 Challenger manual and looks the same in 1973 parts catalog.
If you look at the photo and identify which part, can get other numbers if needed.
19-19-35 seal steering gear worm shaft 2948 859
oil seal steering gear shaft 2267 129
19-19-70 seal steering gear worm sleeve 1822 324
19-01-52 seal steering gear reaction upper 1822 151
o ring steering gear reaction lower 1822 149
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Salty Dog
« Reply #101 on: March 09, 2016 - 05:47:19 PM »
Thanks!
What's the part number on seal on the bottom right of the drawing? I can't quit make it out.
Offline 73440
« Reply #102 on: March 09, 2016 - 08:12:04 PM »
Thanks!
The one at the far right last item is seal steering gear worm shaft 2267 129
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Salty Dog
« Reply #103 on: March 10, 2016 - 05:56:20 AM »
That's probably the seal that is bad. It leaks right where the column connects to the box. Is that seal just pressed in?
Offline CUDA JAS
  • vroooooom!
« Reply #104 on: March 10, 2016 - 09:01:07 AM »
Yes it is just a press fit.
As mentioned above, getting it out while assembled will be the hard part.
Jason
74 'cuda 360/727
