Author Topic: Edelbrock 440 Victor EFI Cuda Hood Clearance  (Read 1707 times)
Offline WildJones
« on: December 11, 2015 - 01:03:46 PM »
Hey guys,
I was curious if anyone here knows if the Edelbrock Victor Efi will fit underneath a stock '70 Cuda hood with something like a Fast or Fitech throttle body on top? I'm debating between a Performer RPM with TBI or the Victor with MPFI if it will fit under the hood.
Thoughts?
Thanks!
95682
1970 Cuda
Re: Edelbrock 440 Victor EFI Cuda Hood Clearance
« Reply #1 on: December 11, 2015 - 04:42:47 PM »
I was able to use the victor intake with an Accufab throttle body as it is only 1.7" tall under a 68 RR hood using a drop base 3" Air cleaner  if the t body is taller it would not fit
Offline cudabob496
« Reply #2 on: December 14, 2015 - 02:42:30 PM »
on the Cuda hoods, you can remove the brackets over the air cleaner, and give yourself more room
2011 Kawasaki Z1000
Offline WildJones
« Reply #3 on: December 15, 2015 - 12:09:57 PM »
Hmmm thanks for the replies. I've spent the last couple days on Google looking around and I haven't come across too many Cudas running this intake on a RB.
Just trying to decide if I should run my Performer RPM and go TBI or if I could squeeze in a Super Victor with the MPFI and if it did fit, would mpfi be worth the added cost.
Sent from my HTC6500LVW using Tapatalk
95682
1970 Cuda
Offline jimmycuda71
  • The Money Pit
« Reply #4 on: December 15, 2015 - 12:39:19 PM »
I am running 440 with the Victor EFI and a Fast Throttle body on a 73 Cuda . Mine doesn't even come close to closing. I had to use a 1" spacer under the air cleaner to clear the throttle arm on the fast throttle body. Even with the drop base on the air cleaner it was not even close.
Jimmycuda71
« Last Edit: December 15, 2015 - 12:50:51 PM by jimmycuda71 »
Offline WildJones
« Reply #5 on: December 15, 2015 - 03:40:18 PM »
Jimmycuda71
So what did you do to remedy that? Running around without a hood or did you get an aftermarket/modify your hood?
EDIT: I was thinking maybe an AAR hood would clear. I saw someone use a TA hood on a challenger since it has the elevated hood scoop, but I dont think the AAR hood offers too much more clearance.
95682
1970 Cuda
Offline jimmycuda71
  • The Money Pit
« Reply #6 on: December 15, 2015 - 04:49:36 PM »
I have done nothing yet. Jut getting finished with the build. I am sure everyone on here is going to boo me, but I am leaning towards getting a cowl hood. I thought about going with an AAR hood or I have a very nice flat hood and thought about putting a six pack scoop on it, Just can't make up my mind.
I have a nice bulge that is for sale. freshly painted rally red if anyone is interested.
