Author Topic: Single yellow cable on steering column, where does it go ?  (Read 806 times)
Offline johannes
« on: December 11, 2015 - 03:44:35 PM »
Gentlemen.
When re-installing the steering column, I find a "single" yellow cable that runs parallell with all the other cables at the lower end of the steering column.
I suspect it is for the small light bulp sheading a small green light on the ignition key?
Question is where does this sigle fe-male spade connect?
Pictures most welcome.
Offline anlauto
Re: Single yellow cable on steering column, where does it go ?
« Reply #1 on: December 11, 2015 - 05:53:41 PM »
In order to plug that in, your car would have had to be equipped with the A01 light group which adds a separate harness  under the dash which that plugs into....no harness....no plug....If you have the harness look for a single yellow female...
Offline johannes
« Reply #2 on: December 12, 2015 - 05:50:37 PM »
Thanks !
So I'm looking for a SINGLE yellow female,..not a large plug with an available female connector ?!
