Author Topic: Stall?  (Read 2173 times)
Offline GoMangoR/T
Stall?
« on: December 13, 2015 - 03:22:03 PM »
I'm in the process of restoring my 70' Challenger R/T and was wanting something more then just the stock stall. Its a 440 4bbl with A?C and nearly everything is being put back to stock except I have long tube headers and just a little bigger cam but nothing to crazy. I was thinking about a 2800 stall and have no idea about what brand
What are y'alls thoughts?
Thanks
Offline cudabob496
Re: Stall?
« Reply #1 on: December 13, 2015 - 04:46:10 PM »
what's your rear end ratio?
2011 Kawasaki Z1000
Offline GoMangoR/T
Re: Stall?
« Reply #2 on: December 13, 2015 - 06:10:14 PM »
Re: Stall?
« Reply #3 on: December 13, 2015 - 06:15:54 PM »
You want to make sure your converter is locked at highway speed
 You can use this to figure it out http://vexer.com/automotive-tools/speed-rpm-calculator
Offline cudabob496
Re: Stall?
« Reply #4 on: December 14, 2015 - 02:17:39 AM »
Is that really necessary. I have a 3500 stall Hughes converter (non lock out), and I cruise on the hwy at 3000 rpm.
I have a good stacked plate B&M tranny cooler in front of radiator.
2011 Kawasaki Z1000
Offline moper
Re: Stall?
« Reply #5 on: December 14, 2015 - 07:43:49 AM »
If the car is primarily a street car - meaning it's driven around all the time on local roads, highways, etc... Then the rule to stay with is what Chryco said... Keep it under your highway cruise rpm. I don't like to have any more than 2500 for most street cars. If your car is doggy with that, chances are there's something else mismatched.
If the car is dual use - racing too - then things are a little different because the assumption is you are willing to live with les mileage and more rpm, and less part throttle response that a higher flash stall will deliver - all for the sake of a higher stall speed at full throttle. For the most part, the modern higher quality convertors can feel tighter at part throttle than at full throttle. But you'll have to buy a good one for that. For the most part anything of an older design (say it's model has been out for longer than 4-5 years) will feel "spongy" at part throttle with milder gearing and higher flash stall speed.
Offline GoMangoR/T
Re: Stall?
« Reply #6 on: December 14, 2015 - 10:43:34 AM »
Thanks guys for all the help I think I'm going with a 2500 stall. I found this one on summit and it seems to be what I need http://www.summitracing.com/parts/hup-24-25/overview/make/dodge
Offline cudabob496
Re: Stall?
« Reply #7 on: December 14, 2015 - 01:54:55 PM »
I paid $400 for a Hughes 3500 stall. 22 years ago. So far, seems to beworking very well. Maybe I got lucky.
2011 Kawasaki Z1000
Offline msbaugh
Re: Stall?
« Reply #8 on: December 14, 2015 - 02:05:35 PM »
I fell into the dynamic 9 1/2" fab going on.  Will have my first test drive this week. 3000-3400 stalk but very efficient with good street manners
Offline cudabob496
Re: Stall?
« Reply #9 on: December 14, 2015 - 02:40:38 PM »
If you like to smash the throttle, and you are getting challenged on the street, I'd go at least 3200.
Also, to avoid future problems, buy a quality converter, spend the money now.
For my 99 Trans Am, I bought a Yank 3200 with lockout. Was $800, but supposed to be worth it.
So far, working great.
2011 Kawasaki Z1000
Offline moper
Re: Stall?
« Reply #10 on: December 15, 2015 - 12:57:00 PM »
Basing entirely on the post regarding "challenged on the street" I'd say you are more of a "racer" than a "cruiser". So no, you were not lucky. You have one that matches your driving and use.
