Author Topic: SEM primer aerosol  (Read 1812 times)
Offline dave73chally
SEM primer aerosol
« on: December 13, 2015 - 05:08:07 PM »
Anyone use SEM high build or self etching primer in an aerosol can? Read a lot of good reviews on some other hot rod forums.
73 Challenger
Offline lulurocks
Re: SEM primer aerosol
« Reply #1 on: December 13, 2015 - 09:31:19 PM »
Im not starting a debate just giving my  :2cents:
Every single sem product i have used has been top quality , that being said do your reasearch on how the specific product your using is designed to be topcoated with, and how.
I have used the sem high build on interior parts , and top coated with sem trim black .. Worked awesome.
If your using it on the body , be diligent with your research to make sure its compatable with your "paint system"
Most 1 part primers dont play nice with 2part paint ...
Good luck :)
Offline js29no
« Reply #2 on: December 14, 2015 - 11:32:01 AM »
SEM makes grate products! there self etch primer is vary good. I have used it to spot in small areas of bare metal, then 2 part surfacer, then base/clear. I don't think I would use rattle can primer then use A spray gun top coat over it. :2cents:
« Reply #3 on: December 14, 2015 - 05:48:47 PM »
 What about a topcoat of their single stage hot rod black over the top? I'll be using this on an old gas pump project not the car.
But if it went well I would think about using it on the car...would make prepping in stages, panel by panel a lot more feasible for the home hobbyist with limited space. Nuts?
73 Challenger
Offline rUNCHARGER
« Reply #4 on: December 14, 2015 - 06:21:56 PM »
I used it on my shaker bubbles. I would not use any aerosol products on large body panels though, just way too much at risk. If I have a problem with a shaker bubble I can refinish it with a few hours work and I don't have to match the rest of the car.
Sheldon
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #5 on: December 14, 2015 - 06:48:36 PM »
works great!
Lots of cleaning before use and they will work great every time.
« Reply #6 on: December 14, 2015 - 07:14:46 PM »
works great!
What have you used it on? Ever exterior panels?
« Last Edit: December 14, 2015 - 08:30:04 PM by dave73chally »
73 Challenger
Offline lulurocks
« Reply #7 on: December 14, 2015 - 07:18:19 PM »
Try it on a peice of scrap metal   Before you. Put it on you gas pump .  Sem products seem to have alot of solvent in them and need alot of flashoff time. Sem tech sheets tell you all the compatable products for each product.
*****As for panel by panel on you car you would save alot of money in if you bought a cheap hvlp gun and  a quality 2k primer   To spot prime with ,  (example  $15 bucks for 4oz can of 1k aerosal .   Or $ 50 bucks for half a gallon of  quality 2k epoxy prime or prime surfacer).  The payback is fast if your doing an entire car.
 :2cents: :2cents:
« Reply #8 on: December 14, 2015 - 08:18:48 PM »
Mostly interior parts. works great
I've used the etching primer on engines, then painted the engine and have had decent success rate.
