Author Topic: affects of decrease combustion chamber by 6cc  (Read 3456 times)
Offline Todd440
Re: affects of decrease combustion chamber by 6cc
« Reply #15 on: December 17, 2015 - 08:40:15 PM »
Sorry about that!  I was using the iPad, and couldn't find the proper symbols.  Once you do it a few times, you can do it on a calculator in less than 30 seconds.
So, if you have a flat top KB, probably the 237 piston , and zero deck, you'd be 10.32  to 1 with 84cc heads, and 10.92 with the 78cc TF heads.  That's assuming you have a composite head gasket at .039 thick, which most are.
Also, never assume the advertised CC's of products.  You'll find they are all over the board.
Offline GreenFish
« Reply #16 on: December 18, 2015 - 12:12:46 PM »
 :cheers:  Thanks man, That's about what I was thinking in my head. Not that big of a difference. I could even go with a thicker head gasket if 10.92 is too high i suppose.
« Reply #17 on: December 18, 2015 - 12:46:18 PM »
Quench is more important than compression so stay with .040 gaskets [ I would use Cometic with alum heads ] & 10.9 compression should work great
Offline GreenFish
« Reply #18 on: December 20, 2015 - 10:36:42 AM »
Cool, thanks
