Author Topic: How to insulate or soundproof roof??  (Read 8578 times)
Offline 69CHARGERMD
« on: December 15, 2015 - 08:02:57 PM »
I am not using a vinyl top on my 70 challenger,,,,and put a new roof on the car,,,,,
Question,,,,
What can I use for sound proofing the roof before I install the headliner ??
I have some phat mat that used on the floors, etc,,,,but wasn't sure if this would be a good option for the roof or if it would not stick to the roof over time,,,,,
Any thoughts on lizard skin??
Trying to keep heat out,,,avoid the car sounding like a tin can inside,,,etc
Thx for any thoughts.  :thumbsup:
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 69CHARGERMD
Re: How to insulate or soundproof roof??
« Reply #1 on: December 15, 2015 - 08:06:17 PM »
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline djw383
« Reply #2 on: December 15, 2015 - 10:11:19 PM »
Offline cordodge
« Reply #3 on: December 15, 2015 - 11:37:27 PM »
Hey, yeah I covered my roof with dynamat then installed the headliner, roof sounds like lead now when you tap on it.
Bruce
1970 challenger 95% done
1969 roadrunner in progress
1969 D-100 13,000 mile truck
1969 L-700 tilt cab in progress
2007  Dodge Ram 4x4
2017 hyundia Santa fe ultimate
1977 VERY UNDERSTANDING WIFE !! 😇
Offline 69CHARGERMD
« Reply #4 on: December 16, 2015 - 10:19:31 AM »
Cool. I will put some of the phat mat I have and that should work. Thx guys !!
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 70 Grand Coupe
« Reply #5 on: December 16, 2015 - 03:56:11 PM »
I too used NOICO sound deadening mat and also the die cut insulation that I clued with 3M adhesive to the NOICO sound deadening. Might be a little overboard, but what the heck.  :2cents: Good luck.
Darcy
 :canada:
Offline TelisSE440
« Reply #6 on: December 16, 2015 - 05:18:12 PM »
Dynamat is one of the soundproofing mat you could use.
Offline 69CHARGERMD
« Reply #7 on: December 23, 2015 - 04:37:05 PM »
Thanks guys.
I used phat mat and used some 3M to keep it in place. Hopefully it doesn't sag with time.
Thx guys !!
« Last Edit: December 23, 2015 - 07:18:03 PM by 69CHARGERMD »
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline djw383
« Reply #8 on: December 23, 2015 - 06:25:55 PM »
Fat Mat Mega Mat has adhesive like dynamat.
Offline 69CHARGERMD
« Reply #9 on: December 23, 2015 - 07:22:35 PM »
djw,
Thanks for the reply.... :cheers:
The Phat Mat I have seems to have some adhesive,,,but didn't seem very sticky ( 65* here today ) ,,,especially for the roof
( for the floors and doors I just peeled off the backing and layed it in place )
The 3M adhesive seems like liquid cement once it dries,,,so I added it as well for the roof portion.
Plan now is to get the headliner in,,,,and start more work on the interior..... :woo:
Curious how you guys did your doors ?? :popcorn:
did you just do the frame portion that is covered by the door panel ? or did you guys stick it to the actual inside portion or skin of the door ( on the other side of the glass ) ?
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline cordodge
« Reply #10 on: December 23, 2015 - 10:48:48 PM »
Hey Doug , myself I covered the door frame behind the panel. Doors sound really solid when closing and I think it is better than putting it on the outside panel as that would leave a big gap where road noise could still enter the cabin but that's just my  :2cents:.
Car is looking awesome BTW
Bruce
2007  Dodge Ram 4x4
« Reply #11 on: December 24, 2015 - 02:13:44 AM »
I installed my NOICO SOUND DEADENER to the inside door skin, refer to pic below. Sorry I don't have a close up handy but I think you get the jest of it  :2thumbs:. I also did the same with the rear quarter panel behind the quarter glass. I will finish up with a layer of sound deadener on the inside door/quarter glass in lieu of plastic dust cover........sweet! Good luck!  :2cents:
Darcy
 :canada:
Offline TelisSE440
« Reply #12 on: December 24, 2015 - 08:37:09 AM »
Darcy, did you put sound deadener under the dash where the factory jute for the heater box is?
Offline cordodge
« Reply #13 on: December 24, 2015 - 08:43:48 AM »
I did, right from the bottom of the windshield to the bottom of the rear glass and all of the roof along with the sides,100% covered
Bruce
2007  Dodge Ram 4x4
Offline 1 Wild R/T
« Reply #14 on: December 24, 2015 - 09:59:40 AM »
One thing I've seen done on roofs that I feel makes sense, cut the sound deadener into small squares, maybe 3x3 that way if a square comes loose it doesn't pull a whole roof section loose just a small square....   And yes the 3M spay adhesive has got to help.... Thought I would look for the high temp version....
