Author Topic: 74 disc setup on a 70 Cuda  (Read 2533 times)
Offline CudaHead
« on: December 16, 2015 - 09:53:49 AM »
I just purchased an entire front suspension from a 74 Cuda.
It has a stock Disc Brake setup on it.
Should I rebuild this and put it on my 70 Barracuda or should I buy a new setup?
If new, which setup would be recommended?
If rebuild is suggested, any suggestions on what to do with the Calipers?
Offline anlauto
Re: 74 disc setup on a 70 Cuda
« Reply #1 on: December 16, 2015 - 09:57:13 AM »
You can get remanufactured calipers for the 1974 set-up as close as your closest Auto Parts store. They're reasonably priced maybe $30 each.
You can get hoses, pads, bearings, dust shields...everything you need, Why would you want to spend big bucks on an aftermarket system ?
Offline CudaHead
« Reply #2 on: December 16, 2015 - 10:01:33 AM »
I like the way you are thinking.
So just use the spindles and bearings and get new Calipers and Rotors?
Offline anlauto
« Reply #3 on: December 16, 2015 - 10:08:25 AM »
Yup...rotors are pretty cheap too...Like $40 each at RockAuto
« Reply #4 on: December 16, 2015 - 10:49:25 AM »
Try shipping it on Greyhound. Better prices for smaller, heavier boxes than traditional shipping methods.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #5 on: December 16, 2015 - 11:13:34 AM »
FYI....spindles for a '70 are different than a '74 so be specific when ordering rotors, etc.
Offline anlauto
« Reply #6 on: December 16, 2015 - 11:32:13 AM »
YES...different bearing size, different rotors etc...
Offline JoeGrapes
« Reply #7 on: December 16, 2015 - 11:41:31 AM »
I did just that. I used the entire front brake setup from a '74. It just bolted right on. I now have Wilwood disc all around. I just think it looks better thru the Billet Specialties I'm using.
Offline CudaHead
« Reply #8 on: December 16, 2015 - 12:46:32 PM »
Thanks for responding. I looked on Rock Auto and I think I can get everything I need. I will use the spindle and the and backing plate and mounting brackets and will order the rest.
I have Drums on the front now. Will I need to change the Master Cylinder?
Offline anlauto
« Reply #9 on: December 16, 2015 - 12:50:00 PM »
Yes...If you look at your drum master cylinder it has two equal chambers because all four wheel cylinders are roughly the same size.
A disc brake master cylinder has one large and one small chamber because the disc brake pistons are a lot larger and require more fluid movement. :2cents:
Offline YellowThumper
  • I left the snow for this?
« Reply #10 on: December 16, 2015 - 01:28:04 PM »
Also need to change proportioning valve.
Factory one or adjustable aftermarket one.
« Reply #11 on: December 17, 2015 - 04:48:58 PM »
Also the master for drums will have a residual pressure valve which can cause the disc brakes to drag
