Author Topic: window trim Q: 'Cuda and Chally the same?  (Read 701 times)
Offline ec_co
« on: December 17, 2015 - 04:38:02 PM »
question: is the front window trim interchangeable between e-bodies?
unfortunately I had to literally rip out the trim because of so much goop/tar used to seal the window and the trim years ago, couldn't find an alternate way :(  lower and lower corners are fine, but I need the sides and top. Are they interchangeable with the same year Challenger?
'70 Barracuda /6 3spd BH23C0E
If at first you don't succeed, skydiving is not for you
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: window trim Q: 'Cuda and Chally the same?
« Reply #1 on: December 17, 2015 - 04:44:34 PM »
Correct me if I'm wrong someone, but I do not believe they are the same.
I know the rear window trim is different as well as any trim for the sides.
Offline rUNCHARGER
« Reply #2 on: December 17, 2015 - 05:25:36 PM »
The rear is different, front is the same.
Sheldon
Offline ec_co
« Reply #3 on: December 17, 2015 - 05:53:21 PM »
Sheldon
that is AWESOME! I knew the sides and back wouldn't but was hoping the front would. I have a source for the OEM pieces I need, but they came off a '70 Challenger
Thanks Team!
 :cooldancing:
