Author Topic: Big Block Bell Housing  (Read 2005 times)
Offline garyp
« on: December 18, 2015 - 05:59:18 AM »
I am converting my 73 challenger back to a 4 speed (A833) and looking for bell housing. I found one on ebay but the guy is not sure if it will fit a 440. the casting number is 2468370 were can I find info on this bell housing ? He said the bell housing is from a 1965 B BODY 361 OR 383 BIG BLOCK  10 I/2" CLUTCH thanks
Offline anlauto
Re: Big Block Bell Housing
« Reply #1 on: December 18, 2015 - 06:58:57 AM »
That has the small bearing retainer hole. So it would depend on the bearing retainer size on your transmission. A later transmission will not fit. :2cents:
« Reply #2 on: December 18, 2015 - 07:57:17 AM »
unless you get the hole bored
Offline anlauto
« Reply #3 on: December 18, 2015 - 08:11:27 AM »
....unless you get the hole bored :grinyes:
Offline garyp
« Reply #4 on: December 18, 2015 - 01:31:22 PM »
it is a A-833 3 speed with Overdrive transmission from the Mid-1970's .  3rd gear is actually Overdrive with a .073 to 1 ratio, and 4th gear is direct 1 to 1 ratio
Offline rUNCHARGER
« Reply #5 on: December 18, 2015 - 04:13:41 PM »
Eee: I don't think anyone makes a big block bellhousing that will work with one of those. They have a huge bearing retainer.
Sheldon
Offline anlauto
« Reply #6 on: December 18, 2015 - 04:19:52 PM »
I would contact Brewers.... :2thumbs:
Offline slsc98
« Reply #7 on: December 18, 2015 - 09:32:40 PM »
 :iagree:   Mr. Brewer will, in the time of a short phone call, cut directly to the correct -- and your best -- option.
Best o' Success!
« Reply #8 on: December 19, 2015 - 09:01:46 PM »
Just mill down the front brg retainer to 4.80 " lots of belhousings with the 4.80 hole
Offline ShelbyDogg
« Reply #9 on: December 27, 2015 - 01:08:01 PM »
Cost less that $20 each at a machine shop.
Have the 5.25 retainer on the trans turned down to 4.80 and have the bell housing 4.35 opened up to 4.80. have them leave a few thousands for a close fit.
This is how I put the 833OD behind my small block with mismatched parts.
