Author Topic: Torqueflite Dust Cover  (Read 1583 times)
Offline chargerdon
« on: December 18, 2015 - 05:55:21 PM »
I need a dust cover.    Is the dust cover the same for a 904 and 727 ??
Re: Torqueflite Dust Cover
« Reply #1 on: December 18, 2015 - 09:52:28 PM »
Nope all are different , I assume you are working with a small block in this case as the big block is also different for a 727
Offline cudabob496
« Reply #2 on: December 18, 2015 - 10:27:54 PM »
easy to make
2011 Kawasaki Z1000
Offline chargerdon
« Reply #3 on: December 19, 2015 - 07:05:44 AM »
yes, LA 360.     I guess Ill just put up some cardboard to make a template and then make one.
« Reply #4 on: December 19, 2015 - 08:45:46 PM »
do you have a bead roller , you will need a rib or 2 in it
Offline Todd440
« Reply #5 on: December 19, 2015 - 08:56:44 PM »
Where ya located?  I should have a stack of them, 727 or 904?
Offline msbaugh
« Reply #6 on: December 19, 2015 - 09:44:38 PM »
Is there any reason to actually have one??
Offline chargerdon
« Reply #7 on: December 20, 2015 - 08:41:54 PM »
904 near Raleigh, NC.   to go with 360 la engine.    Also, will LATER be swapping the 904 for a A518.   No dust cover for it either.
send me an email on how much you want for it.   torockio@yahoo.com
