Author Topic: High Beam Issue  (Read 1126 times)
Offline flagcraig
High Beam Issue
« on: December 19, 2015 - 02:59:07 PM »
Does a 72 Challenger have the foot high beam press?  During tear down I don't remember if it had one.
After restoration I cannot get the high beams to turn off.
I'll dig into the electrical but wanted to check to see if I forgot to put in the foot high beam press.
Thanks
Offline rUNCHARGER
Re: High Beam Issue
« Reply #1 on: December 19, 2015 - 03:13:19 PM »
Yes, it has a foot operated hi beam switch.
Sheldon
Offline roadman5312
Re: High Beam Issue
« Reply #2 on: December 19, 2015 - 03:22:16 PM »
With no dimmer switch the lights shouldn't work at all.   :2cents:               :rebel:
Offline TelisSE440
Re: High Beam Issue
« Reply #3 on: December 20, 2015 - 09:43:35 PM »
As Mark said the front lights current goes through that switch, in a correct restoration, you shouldn't have neither high nor low beam lights.
Offline 70chall440
Re: High Beam Issue
« Reply #4 on: December 21, 2015 - 12:52:17 AM »
Current Mopar
Past Mopars
Offline Tasmanian Devil
Re: High Beam Issue
« Reply #5 on: December 21, 2015 - 04:36:18 PM »
            Look for the 3 wires that would have gone to the dimmer switch, maybe stuffed behind the kick panel. I'm sure somebody just wired them all together. Then get a dimmer switch and connect them to it.
