Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Screw broke off in tail light assembly!
« previous
next »
Print
Pages: [
1
Author
Topic: Screw broke off in tail light assembly! (Read 1390 times)
Wadmin1021
Jr. Member
on:
December 22, 2015 - 08:23:03 AM »
My husband and I received several parts with the '71 Barracuda that we are currently restoring. Two of the parts that came with the car were the tail light assemblies. However the left rear assembly came with a screw broken off in it. We have desperately tried getting it out to no avail. We have tried vise-grips, WD-40, drilling the screw (drill bit keeps sliding off), heating it up, etc! Any thoughts or tricks? Or if we need to get a new one, where can we find them? Here are some pics! Please help!
Logged
https://youtu.be/OEKt5K71CDM
A couple that plays together, stays together!
'71 Plymouth 'Cuda named Claudia w/ 440 4-barrel and TF AT
blown motor
Resident
Re: Screw broke off in tail light assembly!
Reply #1 on:
December 22, 2015 - 09:16:11 AM »
It looks like that housing is some kind of a metal alloy. Is that correct? Set a nut on top of the screw and very carefully weld it. This will heat the screw and loosen it plus you will be able to put a wrench on it. You will have to be very careful of the heat created when welding. I'm not sure how much heat the alloy will take.
Last Edit: December 22, 2015 - 09:21:36 AM by blown motor
Logged
EbodyMod
Jr. Member
Will it ever be finished????
Reply #2 on:
December 22, 2015 - 10:59:04 AM »
Or you can take a die grinder or dremel tool cut it off flush, use a center punch to get a guide mark and then drill it out
Logged
Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
soundcontrol
Sr. Member
Reply #3 on:
December 22, 2015 - 11:28:37 AM »
I would try a wirecutter, pretty small, so it's able to get a grip and turn, and not too sharp, so it won't cut it off so easy. It will either loose up or break.
Logged
/ Ken
Restoration thread:
http://www.cuda-challenger.com/cc/index.php?topic=102525.0
topic=108917.new#new
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
December 22, 2015 - 11:26:46 PM »
use some wax & warm the area so the wax will flow in , it may help
Logged
Wadmin1021
Jr. Member
Reply #5 on:
December 23, 2015 - 09:15:24 AM »
We got it! We used a screw extractor and eventually got it out! Shew! Thanks guys!
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
