Author Topic: Cuda Exhaust with a triangulated 4 link - anyone make one  (Read 7247 times)
Offline 70chall440
« on: December 23, 2015 - 01:40:49 AM »
I am searching for a source for an exhaust system for my Cuda (headers to tips). I am running a 416 stroker and a 4 speed with TTI headers and will be "trying" to route it through the rear valance. Anyone done this or seen anyone making a system? I am thinking of ordering a generic kit from MF or someone then build it myself (I worked in exhaust for while previously and have built systems using kits before).
On the same subject, I am thinking of using 2.5" instead of 3" as I am not sure I need it and don't want to give up the ground clearance, plus it is pretty tight in the rear with the triangulated 4 link.
Any suggestion/comments would be appreciated.
Current Mopar
Past Mopars
Offline EbodyMod
  • Will it ever be finished????
Re: Cuda Exhaust with a triangulated 4 link - anyone make one
« Reply #1 on: December 23, 2015 - 01:59:24 PM »
 :wavingflag: Depending on the four link TTI makes nice kits and if it similar to RMS street lynx it should fit fine
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline 70chall440
« Reply #2 on: December 23, 2015 - 05:26:42 PM »
Thanks, I will look into them.
Current Mopar
Past Mopars
Offline crash340
« Reply #3 on: December 23, 2015 - 06:05:51 PM »
Post a couple of pics of what you have under there with the wheels fitted
Greg
73 Cuda
Brisbane, Australia
Offline 70chall440
« Reply #4 on: December 23, 2015 - 07:04:13 PM »
Not sure I understand what you are saying, what exactly do you want to see?
Current Mopar
Past Mopars
Offline crash340
« Reply #5 on: December 24, 2015 - 01:20:19 AM »
get under the car, lay under the gas tank and take some pics to see what room you have for us
Greg
73 Cuda
Brisbane, Australia
Offline 70chall440
« Reply #6 on: December 24, 2015 - 01:21:53 AM »
Roger, I will get some tomorrow.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #7 on: December 26, 2015 - 08:43:51 PM »
Here are some pics. When I get the car back up on the lift, I will be able to figure it out.
Current Mopar
Past Mopars
Offline EbodyMod
« Reply #8 on: December 26, 2015 - 08:46:38 PM »
 :wavingflag: is that the system from air ride, just with coilovers
Offline 70chall440
« Reply #9 on: December 26, 2015 - 08:52:40 PM »
No, I designed and made it myself from parts I purchased from Art Morrison (they are local). Basically I bought a generic triangulated 4 link system and then used the components to make it work. When I did this, there were not many if any kits for an E body 4 link set up.
Current Mopar
Past Mopars
Offline crash340
« Reply #10 on: December 26, 2015 - 10:12:54 PM »
with A LOT OF WORK you could probably get a 3" set of pipes in there, even still, a set of 2 1/2'' will be tight, I would be going up between the diff center and the top link then over just inside the coil spring following a similar path to the factory pipes.
I have a Magnaflow system and I though I had the verticle rise from the mufler clearanced enough, the diff housing still just strikes it on a full compression, from the muffler make a good tight bend and take it stright up, 90* to the ground as high as you can before bending over the housing to the rear. I think if you got some 90* bends you could manage it, Im going to do more work on mine one day to get it right.
Greg
73 Cuda
Brisbane, Australia
Offline 70chall440
« Reply #11 on: December 26, 2015 - 10:17:38 PM »
Fortunately in my misspent youth I worked at an exhaust place so I have a concept of what I am doing with regards to it. I am going with 2 1/2 all the way, I think 3" is just going to be too big and remove any room I have. With the coil overs and the 4 link, the rear axle cannot hit the frame at full compression, so I might even snake out the side but we will see. I'd love to buy an exhaust pipe bender but space is being reduced in the shop.
Current Mopar
Past Mopars
« Reply #12 on: December 26, 2015 - 10:28:04 PM »
For custom applications I buy stainless mandrel bends and make my own.
Offline crash340
« Reply #13 on: December 27, 2015 - 01:24:58 AM »
buy a Magnaflow system in 3" and a few mandrel bends and go for it Mike
Greg
73 Cuda
Brisbane, Australia
Offline 70chall440
« Reply #14 on: December 27, 2015 - 02:18:05 PM »
I don't have any experience welding stainless, but I guess this is a good time to learn.
Current Mopar
Past Mopars
