Thats the only thing I dont like about my set up is the three bolt header flange, Im not having any gasket blow out issue at all but, given that I wont be dropping the pipes to race it I dont need that flange and its always dragging on speed bumps and driveways so something a little less like a ball socket type would probably be nice, or, like Brad said, cut it off, get a collector to pipe reducer, weld it to the pipes, slip it over the collector and use a band type clamp like the ones MF supply in the kit, in fact, I may even do that to mine if it gets to me.
