Author Topic: Determining drive shaft length ?  (Read 1187 times)
Offline Racer57
« on: December 28, 2015 - 09:42:09 AM »
I have a Tremec TKO500 and by working with airshocks to change tranny angle and wedges to change differential angle I've gotten the majority of the 70mph vibration out. But there's still a slight rumble when I let off the throttle that I can feel but anyone that's not told about it would ever notice.
Pretending that you do not have a driveshaft, how do you check for the proper driveshaft length ? Once you have that figure, how close does it need to be ? Within 1/4", 1/2",  1" ?
« Last Edit: December 28, 2015 - 05:22:55 PM by Racer57 »
Offline Racer57
Re: Determining drive shaft length ?
« Reply #1 on: December 29, 2015 - 09:09:29 AM »
Anyone ?  :D
Offline 73_Cuda_4_Me
« Reply #2 on: December 29, 2015 - 09:27:37 AM »
Racer57, many on here would not recommend setting tranny angle with air shocks - it makes shock mount the load-bearing point for the whole rearend. They would probably recommend shims on tranny mount to get within specs.
That being said, do you know what yokes you are using? There are different size u-joints used, and that affects final driveshaft length. Larger u-joints = larger yokes/shorter shaft by a bit. I have a 727, so mine won't be similar, but I have about 3/4" yoke showing at tranny seal, sitting on level ground with no load in vehicle.
 :working:
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
« Reply #3 on: January 15, 2016 - 10:54:25 AM »
http://www.dennysdriveshaft.com/how_to_measure.html
This is how Denny's says to measure.
Offline Katfish
  • 70 Challenger
« Reply #4 on: January 15, 2016 - 12:44:18 PM »
I'd push it all the way in, then pull out 3/4".
+/- 1/2" won't matter
