Author Topic: Intake and Shaker hood and Carolina Machine Engines  (Read 7791 times)
Offline usraptr
« on: December 29, 2015 - 08:48:43 PM »
Okay first question.  I have a '70 'Cuda with a matching numbers 440 and OEM Shaker hood.  Rather than install or modify the matching nos. engine, I'm seriously considering buying a crate engine with somewhere between 450 and 500 HP.  The proven engine intake manifold for this build seems to be the Edelbrock RPM Performer dual plain aluminum intake.  However, from what I've been able to gather this intake is considerably taller than the stock iron Mopar 440 intake and would not work with my Shaker hood.  Has anybody run into this issue and how did you solve it?  I've noticed the Mopar Performance makes an aluminum intake, part no. 5153525, that appears to be the stock height of the original iron intake.  Has anybody used this manifold with a 440 and Shaker hood and how did it fit?
Second question:  I talked to Carolina Machine Engines today regarding their 440 builds.  They answered all my questions and their price on a complete turn key engine is just over $8K.  I know you get what you pay for, but from what I've seen they seem like a pretty reputable outfit.  Anybody have any experience/input on their engines?
 :feedback:
Thanks in advance.
« Last Edit: December 30, 2015 - 10:36:11 AM by usraptr »
(Edited 8-1-17)
Offline anlauto
Re: Intake and Shaker hood and Carolina Machine Engines
« Reply #1 on: December 29, 2015 - 08:56:44 PM »
You could buy an aftermarket fiberglass base plate and modify it to the height you'll need  :dunno:
Offline usraptr
« Reply #2 on: December 29, 2015 - 09:11:52 PM »
Alan, I assume you mean a fiberglass Shaker base plate?  But since I'm already paying for a new manifold I'd prefer to just buy one that would fit like the OEM if there is such an animal.  That's why I'm curious if anybody has had any experience with fit of the Mopar aluminum intake.
Thanks for the suggestion.   :ylsuper:  If I can't get an intake to fit, I'll try that route.
(Edited 8-1-17)
« Reply #3 on: December 29, 2015 - 09:53:49 PM »
Would the Holley street dominator be lower and work with a shaker?  :dunno:
Offline rUNCHARGER
« Reply #4 on: December 29, 2015 - 10:00:33 PM »
I agree: Just use the Holley Street Dominator intake. It's stock height and almost as good as the RPM.
Sheldon
Offline jimynick
« Reply #5 on: December 29, 2015 - 10:03:16 PM »
Why not just call Edelbrock and ask them? I'm sure they know the height of their own manifold and have several dual or single plane intakes you could choose from. Just my  :2cents:
Offline rUNCHARGER
« Reply #6 on: December 29, 2015 - 10:30:09 PM »
The RPM is way high, the DP Performer is only as good as a stock manifold. The Holley SD works. The Edelbrock tech line isn't much help unless you're a Chebbie guy.
Sheldon
Offline Katfish
  • 70 Challenger
« Reply #7 on: December 29, 2015 - 10:38:37 PM »
Why not just use your factory block?
$8k seems like a lot to lay out because of the numbers.
Anything that could go wrong would cost less than $8k to fix.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #8 on: December 30, 2015 - 10:26:16 AM »
Second question:  I talked to Carolina Machine Engines today regarding their 440 builds.  They answered all my questions and their price on a complete turn key engine is just over $8K.  I know you get what you pay for, but from what I've seen they seem like a pretty reputably outfit.  Anybody have any experience/input on their engines?
Thanks in advance.
I bought a CME 408 stroker in 2014 for my '71 Challenger.  The thing leaked like a stuck pig.  They denied everything saying they do pressure tests etc.  This after being 2 months late on my engine, because it was "race season" in Carolina.  I even when I sent pics of oil on my garage floor that looked like a crime scene.  I went through the whole engine, had to do a dye test, tightened everything up, replaced the rear main, and still couldn't find all the leaks.  They said they could go through the engine again if I pulled it and paid for shipping.  If they determined it was not their fault, they would charge be labor and materials - this was their "warranty".  There are better out there, but your decision.
Offline Oldschool
  • Member Since 9-05-06
« Reply #9 on: December 30, 2015 - 10:33:03 AM »
Just remember that the lower the intake, the lower the HP - generally speaking....
Ken  --  In Georgia
Offline usraptr
« Reply #10 on: December 30, 2015 - 10:39:38 AM »
Thank you for the input everybody.  Good to know dfrazz.  That gives me some much needed insight.  The Holley Street Dominator intake sounds like the way to go.  I'll check it's specs.
(Edited 8-1-17)
Offline anlauto
« Reply #11 on: December 30, 2015 - 12:41:25 PM »
That's my thought as well...Why build some high HP motor only to have stock type parts.....if you're going to build a motor...BUILD a motor !
Offline sassygreen
« Reply #12 on: December 30, 2015 - 02:26:50 PM »
I have that intake along with a quickfuel (holley) carburetor. Shaker base needs to be modified for the holley's float adjusters. Any way if you want I can take some pics for you. if you want.  <a href="http://s1198.photobucket.com/user/blk08vert/media/cuda/090480x640_zps4e986bb0.jpg.html" target="_blank"><img src="http://i1198.photobucket.com/albums/aa457/blk08vert/cuda/090480x640_zps4e986bb0.jpg" border="0" alt=" photo 090480x640_zps4e986bb0.jpg"/>[/url]
Offline BIGSHCLUNK
« Reply #13 on: December 30, 2015 - 02:57:16 PM »
Shaker clearance/height has been an issue on my HEMI from day one.........  :banghead: It be great to have a factory made shaker base for a HOLLEY style carb  !!!!!!!!!!!!  I've modified my base twice already (lots of time) and still not really correct..  :2cents:
Rant over...  :22yikes:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline usraptr
« Reply #14 on: December 30, 2015 - 03:41:36 PM »
PM sent to sassygreen.
(Edited 8-1-17)
