Author Topic: 383 mopar vs. 383 chevy  (Read 6432 times)
Offline 73restomod
« on: December 30, 2015 - 08:53:14 PM »
This video is from the engine masters series, and the results are really surprising. Make one question the bore/stroke relationship to power production, where, and its pretty cool.
https://www.youtube.com/watch?v=L-uV61qilqU
Re: 383 mopar vs. 383 chevy
« Reply #1 on: December 30, 2015 - 09:26:48 PM »
Makes sense to me the Chev is a stroker with lighter pistons & more stroke  the mopar is a a stock stroke heavy piston combo & would benefit from longer stroke a bit more than a 318 & lighter pistons
Offline 73restomod
« Reply #2 on: December 30, 2015 - 10:02:54 PM »
I was surprised by the low end grunt advantage the mopar had, 40Ft lbs and about 20 horse down low. I knew up top numbers would go to the chev because stock vortecs will embarrass 906s on a flow bench. I was surprised that the 383 mopar could get that kind of port velocity that low with its tiny stroke.
Offline RCCDrew
« Reply #3 on: December 31, 2015 - 08:56:01 AM »
Great vid! Thanks for posting. Always wondered about this.
« Reply #4 on: December 31, 2015 - 10:28:52 AM »
I'm not sure I'd say the 906 is the best factory big block head.  915 has better chambers and 346 flow slightly better.
Offline RCCDrew
« Reply #5 on: December 31, 2015 - 10:43:07 AM »
They did say that they milled the heads so that helped the chamber out some.
« Reply #6 on: December 31, 2015 - 03:25:38 PM »
I'd like to see a do over with a set of Max Wedge heads in the Mopar.
Offline EbodyMod
  • Will it ever be finished????
« Reply #7 on: January 01, 2016 - 12:11:59 PM »
 :wavingflag:Awsome video, it makes me so anxious to get my engine finished and on the dyno. :woohoo:
:wavingflag:  Quit being offended by everything, I am sure you are doing something that upsets me, but I am not complaining about you!!! It is a free county get over yourself!
Offline 1 Wild R/T
« Reply #8 on: January 01, 2016 - 01:24:43 PM »
Is there even an intake with max wedge ports for a low deck?
Offline TelisSE440
« Reply #9 on: January 02, 2016 - 07:39:42 PM »
So Neil you think that the same 383 with lighter pistons would have a slight advantage over the 383 Chevy ? :clueless:
« Reply #10 on: January 03, 2016 - 08:14:01 AM »
Yes I do  , if it can equal the power slinging 700 gram pistons & heavy rods , removing 7lbs from the rotating mass should free up a fair amount of power not being used up internally the other end is you should be able to change the rod ratio & make more tq .
« Last Edit: January 03, 2016 - 03:26:08 PM by Chryco Psycho »
Offline TelisSE440
« Reply #11 on: January 03, 2016 - 09:38:18 AM »
Yes I do  , if it can equal the power singing 700 gram pistons & heavy rods removing 7lbs from the rotating mass should free up a fair amount of power not be used up internally the other end is you should be able to change the rod ratio & make more tq .
So a 46 year old engine with old 906 heads could beat up a Chevy blueprinted engine ? That's cool to hear  :2thumbs:
« Reply #12 on: January 04, 2016 - 10:19:41 AM »
No idea.
Offline Denison636
« Reply #13 on: January 04, 2016 - 03:05:00 PM »
I like to see a do over with small block verses small block with the same stroke.
Think the 340 would kill the 383 then.
Its just a little 340 with a miss
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« Reply #14 on: January 04, 2016 - 08:37:31 PM »
I'm lost on the cam they used... anybody have a link to that?
Want one?  Got one! ... finally
