Author Topic: 1970 B body Hurst shifter in E body  (Read 2450 times)
Offline rftroy
« on: January 05, 2016 - 01:11:21 AM »
I've begun my 505 Challenger project.  I have a spare 1970 B body shifter, which has the longer shift lever arms.
Has anyone ever used that shifter in an E body to get a short shifter throw?
Any interference issues?
I haven't driven an E body for years, but I don't remember the shifter throw being terribly long, so this could be a solution in search of a problem.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 blue;
78 Lil' Red Truck, Red;
70 Challenger S/E.  Soon to be 505 6 pack, Aluminum Hemi 4-speed, 3.55, Plum Crazy
Offline 70chall440
Re: 1970 B body Hurst shifter in E body
« Reply #1 on: January 05, 2016 - 01:45:03 AM »
The e body is vastly shorter. If I had one I would try and trade you as I need one for my Road Runner. When I was younger I tried to cut one down and it is a mess, for the cost of them now (they are repopped and available from Brewers, Year One, etc).
Current Mopar
Past Mopars
« Reply #2 on: January 05, 2016 - 08:47:40 PM »
Yes , I have played with different shifters & levers  to shorten the throw down a lot
Offline 1 Wild R/T
« Reply #3 on: January 05, 2016 - 08:57:05 PM »
Some shift levers have two holes to shorten the throw you use the hole closest to the pivot...   Look here...
http://www.brewersperformance.com/proddetail.asp?prod=OL-E
Offline rftroy
« Reply #4 on: January 06, 2016 - 10:05:06 PM »
If you tried a 70 B bpdy, how did it work for you?
Did it have a good feel, or did the throw end up being too short and require too much force?
Somewhere in between?
Bob
« Reply #5 on: January 06, 2016 - 10:29:21 PM »
Seems to work well
Offline rftroy
« Reply #6 on: January 06, 2016 - 11:21:25 PM »
Thanks.  I'll give it a try.
It's a very simple job to change shifters, so it's no effort to try it.
Robert
Offline ShelbyDogg
« Reply #7 on: January 15, 2016 - 12:07:24 PM »
I used to be able to buy the dual hole plates from the dealer years ago. But now I get stuff at swap meets.
If you have some good drill bits, Your can drill some new holes to convert your arms to have that 2nd hole. I've used a sharp carbide tipped die grinder bit to slowly sneak up on the desired final hole size.  Just make sure that you start with a plate that is at the straight up and down angle when in neutral and facing the shifter. (not 90 degrees to the floor) All plates have different angles cut where they bolt to the side of the shifter forks. If you don't have e-body plates, you want a plate that travels forward and back across an arc and equal distance from neutral in relation to the lower linkage hole in it's corresponding shifter plate. Sometimes flipping plates over or using some from different applications work. The OD ones are cut at a different angle too.
for the shifter mechanism, I've had to cut off the outside shifter leg then weld it spaced out about half an inch. If you look at an E-body shifter, you'll see that that the outside shifter plate is spaced out farther than a b-body shifter.
LOL, I have a welder, I make stuff work.
