The 62" cable was the perfect length. Put it in today and the length was fine but ........as most projects go......... I ran into a couple of new problems. First, when I try to hook it up to the speedometer, it is supposed to just push onto it and snap securely in place. It doesn't. It is very hard to push hard enough to snap into place, as though the cable end is too long. I did get it to snap in but when I drove it the speedo needle bounced all over the place. When I released the clip and let it ride in there with no pressure on it, it work smoothly but could easily fall out of the speedo. Seems like I might need to cut off the end of the cable. Anybody run into this???
Second thing, probably a little more common of a problem, it is very inaccurate. When I'm driving at 25mph the speedo reads 33mph. Is their some way to figure out what gear I would need or any other thing I might need to make it read a little closer to correct. Or is it just trial and error? :dunno
Thanks, Mike
