Author Topic: Common parts that fail / things to keep spares of in an E-Body?  (Read 9318 times)
Offline Grec
« on: January 07, 2016 - 10:28:28 AM »
Now that I'm actually driving my Challenger on a regular basis (woohoo!) I'm thinking about keeping a spare of common parts that fail in the car.
I know the ballast resistor is a good one, and I've heard voltage regulators go out unexpectedly sometimes... Anything else?
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline 340challconvert
  • A66- Challenger Registry
    • A66CHALLENGER.COM
Re: Common parts that fail / things to keep spares of in an E-Body?
« Reply #1 on: January 07, 2016 - 10:44:15 AM »
The fuse-able link at the starter relay is a good part to have on hand.  Always kept a spare in the glove box even years back so I wouldn't get stranded.
I would also keep a spare set of points, rotor and cap back in the old days.  Less problems if you converted to an electronic ignition though on a 70-71 car.
1970 Challenger A66 Registry
Offline mopar jack
« Reply #2 on: January 07, 2016 - 11:11:07 AM »
If electronic I keep a spare ecu, reluctor pick-up, distributor cap, ballast resister, coil, voltage reg, and jumper wire. I carry a spare upper rad hose and fan belt to run the water pump and steering. Most importantly a cel phone and good towing insrurance.
Offline Jousi
« Reply #3 on: January 07, 2016 - 11:45:14 AM »
I have been driving about 20 000 miles in last four summer, my driveline is modern, so no issues there.
But a windscreen wiper system(2-speed) seems to be quite weak and prone to have problems. Also couple voltage regulators have broke. And turn signal switches. Learned also only use quality ball joints and bushes (Moog).
BH23G1B TX9 5.7 Hemi+5-speed
JH23J0B FC7 4-speed
BS23R0B TX9 auto
Offline 74 challenge
« Reply #4 on: January 07, 2016 - 11:57:21 AM »
My only failures have been at the hands of old gaskets so I keep a tube of high Temp RTV.
1-8-4-3-6-5-7-2
Offline Cudakiller70
« Reply #5 on: January 07, 2016 - 12:10:54 PM »
Great thread idea, I'm new to Mopars so this is good to know. Not specifically Mopar but, I keep a better quality tire plug kit (corded not solid rubber) and a 12v air compressor because I don't have a spare, plus it's just faster and easier to plug your tire.
The above is just my opinion
John Adams
Offline 70chall440
« Reply #6 on: January 08, 2016 - 12:24:04 AM »
I once has the stud on the carb break off at the threads; car would idle but I had not way to accelerate because the throttle cable was disconnected, I was wearing a GI field jacket that has a cotton pull tab on the zipper; I removed it and tied the end of the throttle cable to the carb linkage and limped it home. From then till now I keep a small amount of bailing wire in all my vehicles.
Basically, wire, some flex ties, a tube of RTV and some duct tape (of course some basic hand tools as well). If these wont get you to the nearest gas station/repair shop (or home if you are local); cell phone and AAA...
Current Mopar
Past Mopars
Offline Grec
« Reply #7 on: January 08, 2016 - 11:27:02 AM »
Thanks for all the replies, guys. Good stuff.
@70chall440... Love it. Zip ties, bailing wire and duct tape. I can think of a ton of problems that would solve.  :thumbsup:
- 440 Six Pack
Offline YellowThumper
  • I left the snow for this?
« Reply #8 on: January 08, 2016 - 11:37:03 AM »
Water and the radiator stop leak. Never know what might what might get kicked up and make a hole at the high rate of speed we are capable of... :burnout:
My way of thinking is as many small things that don't weigh a lot and kill the trunk space.
Offline js29no
« Reply #9 on: January 08, 2016 - 12:06:06 PM »
All I need is A cell phone with A signal, so I can call for A ride to go get my wrecker. had to do it last summer, bad coil!
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: January 08, 2016 - 01:41:02 PM »
Yep...cell phone (always with me anyway) and my CAA card.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline solarguy
« Reply #11 on: January 08, 2016 - 02:46:14 PM »
Not a replacement part but one of these new micro jump boxes.  I have the XP-10 here http://themicrostart.com/products/micro-starts/  I can tell you it rolls the 340 over no problem and starts my E150 with ease.
Offline 70chall440
« Reply #12 on: January 08, 2016 - 02:49:46 PM »
I might have to get one of those, for traveling and perhaps jumping a vehicle. I wonder how the smaller units do for jumping a vehicle.
Current Mopar
Past Mopars
Offline 1 Wild R/T
« Reply #13 on: January 08, 2016 - 02:58:50 PM »
Commonly fails... Dash boards crack, who wants to lend me their spare?   :roflsmiley:
Another thing that fails? Those 70 style heater water valves, the red & black ones... When I built my car I got one at the local Napa, $12...OE red & black... It failed after about five years, Got another one Napa again.. $26.... It lasted about five years... Napa no longer could get the red/black valve replacement is a 71 & up metal valve.. Wanted to keep the OE look, found one on Ebay... Most were selling for $120-150ish.. I watched & caught one for $90... It lasted about five years.... Are we seeing a pattern here?   :roflsmiley:
« Last Edit: January 08, 2016 - 03:04:33 PM by 1 Wild R/T »
Offline 70chall440
« Reply #14 on: January 08, 2016 - 03:03:34 PM »
that's what the RTV is for...  :roflsmiley:
Current Mopar
Past Mopars
