Author Topic: 1970 steering column in/out play  (Read 3100 times)
Offline TCSS396
« on: January 07, 2016 - 03:23:04 PM »
Has anyone encountered in /out play in the steering shaft if you take the steering wheel and push/pull?
Offline 1 Wild R/T
Re: 1970 steering column in/out play
« Reply #1 on: January 07, 2016 - 04:25:49 PM »
the steering column upper bearing or on of the snap rings attaching it has likely failed...
Offline TCSS396
« Reply #2 on: January 07, 2016 - 04:43:37 PM »
Thank you r/t , do you have any recommendations where I can get a snap ring for it?
Offline TCSS396
« Reply #3 on: January 07, 2016 - 04:44:27 PM »
Or the bearing if that is needed?
Offline 1 Wild R/T
« Reply #4 on: January 07, 2016 - 05:58:54 PM »
Bearing..   http://www.ebay.com/itm/MOPAR-BEARING-Steering-Column-A-B-E-body-Plymouth-Dodge-Chrysler-Cuda-Charger-/221987224555
Snap rings, take it apart & match them up, shouldn't be to hard to source... I believe they are 3/4 external, they are a little different from generic snap rings but standard generic snap rings would work find & I doubt any car show judges would notice
Offline TCSS396
« Reply #5 on: January 07, 2016 - 07:02:47 PM »
👍👍will put this on my list thank you so much for the link & your direction with this r/t
Offline TCSS396
« Reply #6 on: January 07, 2016 - 07:30:00 PM »
The car (as long as I own it) will never be in a judged event, pure enjoyment only!  Lol
Offline 73440
« Reply #7 on: January 08, 2016 - 01:37:42 AM »
I have the same problem with mine, thank you for the info.
Sent from my SM-G900V using Tapatalk
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 73440
« Reply #8 on: January 08, 2016 - 01:40:04 AM »
Was always wondering if it will completely separate while driving one day if I pull back on the wheel.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline TCSS396
« Reply #9 on: January 08, 2016 - 06:28:39 AM »
Hopefully not 👍
Offline TCSS396
« Reply #10 on: January 08, 2016 - 09:11:51 AM »
R/t,  so basically once I take the steering wheel off, if the snap ring is missing this can be the issue alone?  Any ideas How could I check that bearing once the steering wheel is off?
Offline 1 Wild R/T
« Reply #11 on: January 08, 2016 - 09:35:28 AM »
When you pull the steering wheel you expose the lock plate, you remove the lock plate by getting the sleeve in the center off then drive out the roll pin.... Now your looking at the turn signal switch... In the center of the turn signal switch is the bearing, it's secured to the steering column by a plate that also captures the turn signal switch... Three screws & the plate is out.. There is a snap ring on the shaft that passes through the bearing... Then the bearing comes out & the is a second snap ring below the bearing...  After you remove the turn signal switch there are three screws that mount the upper housing to the column, if you remove those it helps in getting the bearing off the shaft..
Once you dig into it the problem should be apparent...
Offline TCSS396
« Reply #12 on: January 08, 2016 - 10:35:01 AM »
Ok  very helpful thank you
