Author Topic: TA Block for Sale in WA State  (Read 885 times)
Offline 70chall440
« on: January 07, 2016 - 11:46:45 PM »
I posted this in the Ebay/Craigslist area but wanted to get it out there in case someone is looking for this block.
TA block for sale @ http://seattle.craigslist.org/est/pts/5387929860.html
340 T/A for sale
 Originally from a Challenger T/A but would be date and type correct for your T/A or AAR Cuda!
 Or for you racers:
 This is the "4" bolt main block and doesn't get any rarer or better than this!
 3577130.TA.340.2
 Vin on block: OB289765
 Engine is currently apart and block and heads just came back from being checked at the machine shop.
 Block has been sonic and magged checked for cracks and is not cracked.
 Block is .030" over.
 Mainline has just been honed. All T/A main caps are intact and included. or swap to aftermarket 4 bolt mains!
 Block needs a .010" decking for cleanup.
 The crank needs some work on the thrust bearing counter weights and isn't usable as is but is included and is fixable.
 Pistons are aftermarket .030" over units of unknown make and are still attached to the 6pack rods.
 Heads are the original T/A castings with the offset rocker arms and enlarged pushrod holes as well as the big vales.
 All the offset rockers are there along with the pushrods.
 Oil pan is a #228.
 Timing cover appears to be a 1973 casting. Part numbers are 3 2951698 05102.
 Engine is missing the 6pack intake, exhaust manifolds, original valve covers and the windage tray, Otherwise it is complete.
 Offered at $10,000.00
 Please no low ball offers it doesn't hurt me to keep this on the shelf.
 Pictures of everything are available.
hr7sq-5387929860@sale.craigslist.org
Current Mopar
Past Mopars
