Author Topic: 67 cuda code help  (Read 1448 times)
Offline DadsCuda
67 cuda code help
« on: January 09, 2016 - 04:40:10 PM »
hey all!
looking for a little insight on my codes.
i have a 67 barracuda notchback and i found a partial build sheet when i ripped the headliner out.
the decoders i've found online don't really help me, as the numbers don't coincide. probably just being dense. and help for this newbie would be greatly appreciated.
thanks!
Offline TelisSE440
Re: 67 cuda code help
« Reply #1 on: January 10, 2016 - 10:34:10 AM »
Offline TelisSE440
« Reply #2 on: January 10, 2016 - 10:41:37 AM »
I forgot... Take a look at your build sheet. Don't look at the last and the line before it, they are just build codes for the assembly line. Take a look at the upper lines, you can see that there are boxes that have a description and below them, a number. For example, take a look in the center where the line reads FLEET ITEMS, you will see below a printed number : "2". Look over it, you can see a numbers which says "62", add the printed "2" as a text, so it says : 622 ("62" plus the printed "2"). Look over the option code list and you can see that your came with a 48 amp battery from factory, doesn't that line over the "62" read battery ?
Offline DadsCuda
« Reply #3 on: January 10, 2016 - 05:09:11 PM »
Ahh! Yes! I was looking at those & that explains a lot. (Insert face palm emoticon here :-\)
Thanks!
Offline TelisSE440
« Reply #4 on: January 17, 2016 - 07:29:05 AM »
Thanks!
You're welcome !  :2thumbs: I remember when I did the face palm too !
