Author Topic: Any idea why left rear marker and taillight would be dimmer than the right?  (Read 1844 times)
Offline Grec
I'm assuming that there's a voltage loss somewhere, but wondering if anyone else has run into this and has a good place to start looking... ?
I need to get new headlight and taillight harnesses anyways, but am hoping to postpone yet another $300+ expense for a bit. :-\ That and tearing the interior apart as soon as I got my car back on the road. Lol.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline roadman5312
      Poor ground probably    :2cents:
Offline TelisSE440
:iagree: X3 Check the marker light case grounding on the rear quarter and tailight case of the bulbs on the tail panel. Are the hazard lights dim too?
Offline JayBee
x4 for bad ground...or...one of them might have the wrong bulb.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Falbz
X5 :iagree:  run a ground wire from left tail lamp socket to a metal part on body  :2thumbs:
Had same issue at one time
Offline Grec
Sounds like I'm looking for a ground issue. :-)
Thanks, guys.
- 440 Six Pack
Offline roadman5312
Thanks, guys.
                     If a ground issue is not the prob, check the wires in the wire connector behind the passenger kick panel.
Offline Grec
Update on this: Yep. Ground issue on drivers-side taillight. It was actually poor grounding of the metal socket plugging into the light housing. One of those deals where if you just wiggled the plug a bit it would work correctly.
A little wire brushing/scotch brite sanding and bending of the little metal tabs did the trick.  :thumbsup:
- 440 Six Pack
Offline TelisSE440
 :2thumbs:
