Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Manual steering conversion
« previous
next »
Print
Pages: [
1
Author
Topic: Manual steering conversion (Read 1002 times)
garyp
Jr. Member
on:
January 11, 2016 - 02:31:13 PM »
Hi I have a 1973 challenger with manual steering and converting to power, my question, is the steering column different ? and do I need to replace it
Thanks
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Re: Manual steering conversion
Reply #1 on:
January 11, 2016 - 02:44:34 PM »
You can just collapse the inner shaft a couple of inches. Not the safest method if you're worried about future collisions, but what are the chances...
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
January 11, 2016 - 11:11:48 PM »
There is more to it than that once you collapse the shaft the nylon pins are broken so the shaft could move upward & disconnect from the coupler , If the retainer pin is actually in place the only thing holding your steering together is a 1/8" diameter press pin that stops the shoes inside the coupler from sliding out , without the press pin really there is nothing holding it together
Logged
mofish
Jr. Member
Reply #3 on:
January 17, 2016 - 10:08:00 PM »
I will be doing this conversion too....so does that mean the steering column needs to be replaced??
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
January 17, 2016 - 10:49:49 PM »
The internal shaft should be the correct one , breaking the nylon pins to shorten the shaft is not really the safest way to do this
Logged
mofish
Jr. Member
Reply #5 on:
January 17, 2016 - 11:57:16 PM »
Ok thanks CP. I appreciate it
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
