Author Topic: Making dents in headers  (Read 3530 times)
Offline soundcontrol
« on: January 13, 2016 - 12:58:17 PM »
Interesting test of denting headers for clearance:
https://www.youtube.com/watch?v=azPKIjxmmdU#t=688
/ Ken
topic=108917.new#new
Offline 1 Wild R/T
Re: Making dents in headers
« Reply #1 on: January 13, 2016 - 01:11:37 PM »
Yup, surprised by the results...
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #2 on: January 13, 2016 - 01:28:04 PM »
bash away!
« Reply #3 on: January 13, 2016 - 02:42:29 PM »
Wow. Save $. Don't buy TTI, buy a set of cheap tubes and a hammer.
« Reply #4 on: January 13, 2016 - 04:17:57 PM »
I got ceramic coated TTI's and a big hammer!  :grinno:
And I'm serious, I wish I wasn't but....
Gotta modify them for a NAG1 with a passenger side starter. I suspect I have to cut the tubes and reroute them.
/ Ken
Offline 73440
« Reply #5 on: January 13, 2016 - 08:41:42 PM »
Maybe the dents make a smaller diameter which raises the velocity which increases scavenging which allows more fuel charge in.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline daveh
« Reply #6 on: January 14, 2016 - 08:39:43 AM »
Ok so when you have ceramic coated hearers what's the best way to dimple them without cracking the coating?
« Reply #7 on: January 14, 2016 - 12:30:22 PM »
Good question, the coating will probably be destroyed on mine when I get started, I'll probably have to both cut, reroute and dent them to fit.
/ Ken
Offline 73restomod
« Reply #8 on: January 16, 2016 - 05:11:20 AM »
You can dimple ceramic coated headers by heating them up and gently massaging them. However don't hit them with ball peen directly, use another hammer to swing and rest the ball peen against the work. Also ceramic coat doesn't tolerate to much movement so if its a big ding you need to make...
Offline TelisSE440
« Reply #9 on: January 18, 2016 - 09:21:32 AM »
I was too surprised by the results, anyway can't I get some cheap headers, do the dents and then ceramic coat them ?
Offline moprr
« Reply #10 on: January 31, 2016 - 07:42:50 PM »
Cheap headers normally have thin flanges which tend to leak. I once bought cheap headers then had them coated after a while I got sick of leaks and replacing gaskets.  I bought a good header with thick flanges and never regretted it .
« Last Edit: January 31, 2016 - 07:47:43 PM by moprr »
« Reply #11 on: January 31, 2016 - 08:07:23 PM »
Thick flanges help, but the size of the weld bead around the port, and the relative flatness off the grinding of all these welds around the ports are factors as well.
If you are willing to weld and grind, you can make a cheap set seal up pretty good.
Offline 360 'CUDA
« Reply #12 on: January 31, 2016 - 09:00:42 PM »
I was surprised they left the headers on the engine when they pounded them. I was picturing all kinds of cracks in the head from the sudden movement.   I cracked a head once when one of my headers hung up on the trailer unloading the car.
Offline TelisSE440
« Reply #13 on: February 06, 2016 - 10:34:55 AM »
I thought that too... Seems that American V-8s  are robust enough...
