Author Topic: Fuel pressure regulator necessary???????  (Read 1915 times)
Offline TCSS396
« on: January 13, 2016 - 10:06:45 PM »
Running a mechanical fuel pump on my 383, ran fine before an old-timer drag racer was determined to put a fuel pressure regulator on it,  ended up making no noticeable difference,  I don't like this piece of hardware on it, any truth to the old timers thoughts? Or should I just take it off and call it a day?
Offline 70chall440
Re: Fuel pressure regulator necessary???????
« Reply #1 on: January 13, 2016 - 10:20:46 PM »
Won't hurt anything since you are not "regulating" the pressure at all. I have never run one on a mech fuel pump engine, not to say that they dont have a place but if you are running a "normal" mech pump, I dont see a real need. Now, if you are running something more exotic and capable of higher pressures (above about 12 psi), you might want to leave it. If you go too high, you can cause issues with the carb flooding.
Lets see what some of the racers say.
Current Mopar
Past Mopars
« Reply #2 on: January 13, 2016 - 10:33:44 PM »
The carb can handle 7 PSI max , 6 is better , if the pump is under 7 PSIthere is no need for the reg
Offline rUNCHARGER
« Reply #3 on: January 13, 2016 - 10:38:24 PM »
6 is where you want it. They can bring their own problems too. I am taking the one off my orange car. It is impeding flow. I am either going to put a lower pressure pusher pump near the tank or a higher flow regulator and I hate the way they look.
Sheldon
Offline 70chall440
« Reply #4 on: January 13, 2016 - 10:47:12 PM »
Think I read somewhere that a normal carb can withstand up to 12 psi (which is why I typed that). Could be wrong, by 6 pack runs around 6-7psi.
Current Mopar
Past Mopars
Offline TCSS396
« Reply #5 on: January 14, 2016 - 08:28:32 AM »
Thanks guys I'm going to probably eliminate it, looks like a lot of nothing going on with it
Offline 70chall440
« Reply #6 on: January 14, 2016 - 10:46:45 AM »
Definitely could have been done better. Hanging all of that on the metal fuel line is an invitation to cracking.
Current Mopar
Past Mopars
Offline TCSS396
« Reply #7 on: January 14, 2016 - 01:35:22 PM »
Yes I'm not fond of it at all
Offline jhaag
« Reply #8 on: January 14, 2016 - 09:13:39 PM »
Lose it...It and all the 90 degree fittings doing more harm than good.  :2cents:
love 70 Challengers
Offline TCSS396
« Reply #9 on: January 14, 2016 - 09:29:19 PM »
Ok 👍absolutely agree
Offline TelisSE440
« Reply #10 on: January 17, 2016 - 04:16:03 PM »
You could move it on the inner fender and then have a flexible fuel line to the carb. Just a thought.
