door hinge rebuild
Author Topic: door hinge rebuild  (Read 1485 times)
Offline greengochallenger
door hinge rebuild
« on: June 04, 2005 - 01:42:36 AM »
I bought a door hinge rebuild kit from year one but it didnt come with any instructions. I got new pins and some bushings. Has anyone rebuilt their hinges?
Offline heminut
Re: door hinge rebuild
« Reply #1 on: June 04, 2005 - 10:07:47 AM »
I did mine, the hardest part was rehanging the doors! BTW, the YO kit is a rip-off! You can go to the local Car Quest and buy the pins and bushings individually for a fraction of what they charge.
1970 5.7 Hemi Cuda
« Reply #2 on: June 05, 2005 - 01:10:22 AM »
yea, i found that out after i spent the $$$. Is there a special tool or drill bit that you need to use?
Offline RUSTY Cuda
  • One big step foward!
« Reply #3 on: June 05, 2005 - 08:23:54 AM »
Tops were cake if the holes are good, just put in the new bushing & pin, the bottoms you can just use the pin if the holes are tight, to add the bushings you have to drill out the holes, I drilled one set, kinda awkward the way the bushings go in, so I did aniothe r(tight) set with just new pins.(oh yea, only drill the middle holes, not the outers! ) Rich.
« Reply #4 on: June 06, 2005 - 01:22:24 AM »
cool,thanks!
Offline Carlwalski
« Reply #5 on: June 06, 2005 - 02:41:57 AM »
The doors weigh a sh!t load eh!!!  :ack:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline RUSTY Cuda
« Reply #6 on: June 06, 2005 - 07:55:54 PM »
NZ, understatement, those puppies weigh a ton, I was surprised when I helped a friend hang 69 charger doors, they were MUCH lighter, I would have thought the opposite!  :dontknow: Rich.
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #7 on: June 07, 2005 - 12:51:02 AM »
You should have seen Red and I taking them down from the rafters... :ack:  Quite a site.  I don't know how we ever got them up there.
Offline Carlwalski
« Reply #8 on: June 07, 2005 - 09:42:31 PM »
 :laughing: Poor REV.  :( They are chunky.  :grinyes:
"Carl givas a hand to move these Challenger doors" -------------------------------------------------------------------> Carl:  :outtahere:
