Author Topic: Detecting exhaust manifold leak  (Read 5555 times)
Offline tommyg29
« on: January 16, 2016 - 03:02:42 PM »
My 400-4 has developed and ticking noise, I think on the left side, and I think/hope its the manifold gasket. I have a hard time telling the difference between that and bad valve ticking. I tried tightening up a couple bolts that were maybe a ratchet click or two loose, but hasnt helped. Under #7 does this look like a leak? Any advice?
Offline soundcontrol
Re: Detecting exhaust manifold leak
« Reply #1 on: January 16, 2016 - 03:06:39 PM »
I had them also, take out the gasket and look at it, its usually visable on the gasket. There is probably some other tricks to find leaks also.
/ Ken
topic=108917.new#new
« Reply #2 on: January 17, 2016 - 09:03:08 AM »
Looks like a leak to me.
Offline tommyg29
« Reply #3 on: January 17, 2016 - 12:14:03 PM »
Can anyone identify the gasket I have so I get the same one  :bigsmile:
Or which one is recommended most?
Offline roadman5312
« Reply #4 on: January 17, 2016 - 12:28:26 PM »
            I've been using Percy's soft aluminum gaskets with very good results.     http://www.summitracing.com/parts/php-66036/overview/year/1972/make/dodge
« Reply #5 on: January 17, 2016 - 07:41:00 PM »
My question is why are you using gaskets at all  the factory never did !
 Just use a thin layer of high temp Ultra copper silicone & bolt it up , gaskets always cause the leaks
Offline tommyg29
« Reply #6 on: January 17, 2016 - 10:05:37 PM »
Thanks for the tips.
I will try without the gasket first and hopefully Ill be able to remove the 6 nuts and bolts without much trouble, though with my luck I know I'll probably break a stud or have some other issue.
Then I hope it fixes the problem. I still dont know for sure its not a valve or rocker noise of some sort.
Offline Racer57
« Reply #7 on: January 17, 2016 - 10:21:00 PM »
If your planning on not using a gasket, take the manifolds to a machine shop to get resurfaced first.
« Reply #8 on: January 18, 2016 - 08:18:56 AM »
just put a straight edge on it , it is probably fine
Offline solarguy
« Reply #9 on: January 18, 2016 - 09:16:08 AM »
Take a look here before you make your final decision.  They work great
http://catalog.remflex.com/
« Reply #10 on: January 18, 2016 - 12:31:12 PM »
I have lost count of how many engine & cars I have built restored or worked on but I have NEVER used gaskets or planed a manifold yet
Offline TelisSE440
« Reply #11 on: January 18, 2016 - 02:56:26 PM »
I will try the next time take off my headers, I will use some rtv seal, hope it works.
« Reply #12 on: January 18, 2016 - 03:48:24 PM »
I could see no gasket working on regular manifolds with a good sealer, but on headers?
/ Ken
« Reply #13 on: January 18, 2016 - 07:22:13 PM »
I used remflex on my headers on the 440. So far they are good.
Offline tommyg29
« Reply #14 on: January 18, 2016 - 08:23:53 PM »
Mine are hp manifolds. Not sure if theyre the originals though.
