Author Topic: Motor not level ? Hemi  (Read 2020 times)
Offline roadman5312
« on: January 16, 2016 - 05:12:26 PM »
    OK, this is bugging the crap out of me. The Hemi in the Challenger when you look at it from the front is tilted up on the left side. No one else really notices unless I point it out. We looked at many Hemi Cuda's and Challengers today at Mecum and it appears it's more a Challenger thing than Cuda. But they all to some degree appear to be crooked. Is this normal  :dunno: We also looked at several shaker cars that the shaker line up in the hood was really bad. High dollar collection cars.   :feedback:
Offline roadman5312
Re: Motor not level ? Hemi
« Reply #1 on: January 16, 2016 - 05:15:58 PM »
Example  picture. See the tilt.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #2 on: January 16, 2016 - 07:52:35 PM »
 :dunno: When we installed the 340 in my Cuda we put a level across the top of the valve covers and made sure the car and engine were both level before tightening the motor mounts.  :dunno:
Worth a look maybe?
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
« Reply #3 on: January 16, 2016 - 09:01:47 PM »
I recall you mentioned during your build that you used an aftermarket engine mounts?
That would be my first suspicion.
Offline rUNCHARGER
« Reply #4 on: January 16, 2016 - 09:31:06 PM »
Probably Schumacher mounts.
Sheldon
« Reply #5 on: January 17, 2016 - 01:20:39 PM »
I'd say that is because builders bolted all the motor mounts parts together tight and then installed the engine. If you leave them all a little loose, you can manipulate the engine to make it level, then torque them all down. However, it is not easy to do in  any way, shape, or form as space is limited and especially if you have headers installed, darn near impossible without an assortment of  extensions and swivels.
Offline TelisSE440
« Reply #6 on: January 18, 2016 - 02:47:57 PM »
Ok, let me say it, in an episode of Graveyard Carz, there was a tilted engine. I will try and search the episode but I remember Mr Worman did what HP2 says, he unbolted some engine mounting bolts and he raised the engine the other side. He fixed it as I remember.
Offline ShelbyDogg
« Reply #7 on: January 22, 2016 - 04:23:57 PM »
It would bug the hell out of me too. I would cut and reweld one of those mounts to fix it.
Offline roadman5312
« Reply #8 on: January 22, 2016 - 06:20:30 PM »
                 Yea I'm planning to remove the right side bracket and slot the holes @ the block.   :rebel:
Offline HP_Cuda
  • Mopar or No Car!
« Reply #9 on: January 22, 2016 - 07:03:02 PM »
I think this would lend to another bonus of mounting the hemi on the Kmember before putting in the car.
Easy access and you can check the level before putting in the car. Even if you found it was off, it's fairly easy to pull the kmember get access fix and problem and you are on your way!!!
 :woo:
« Reply #10 on: January 23, 2016 - 12:30:54 AM »
That's what I did. I let the engine tell me where it wanted to rest level.
Offline TelisSE440
« Reply #11 on: January 24, 2016 - 09:34:20 AM »
Tell us how it went Mark when you fix it  :popcorn:
