Author Topic: convertible a pillar moulding  (Read 3044 times)
Offline norwayduster
« on: January 17, 2016 - 07:33:53 AM »
Rh inside plastic apillar moulding 71 Challenger. Maybe all years cuda Challenger  cnvt are the same? Wanted asap.
John
1971 challenger convertible
Offline 1 Wild R/T
Re: convertible a pillar moulding
« Reply #1 on: January 17, 2016 - 09:52:03 AM »
the convertible part is the same as the hardtop piece, just need to cut the top off... Great way to recycle one with a broken top area...
Offline Finoke
« Reply #2 on: January 17, 2016 - 01:25:03 PM »
I was going to say the same thing  :bigsmile:
Offline AARTA340
« Reply #3 on: January 17, 2016 - 02:09:47 PM »
Good info on the hardtop one being trimed down. :thumbsup:
« Reply #4 on: January 17, 2016 - 04:39:44 PM »
Ok.thanx.
Does anyone have a good one from a ht than? I tried a repro but couldn't make it fit.
Offline A93
« Reply #5 on: January 18, 2016 - 12:56:18 PM »
I believe the convertible ones are unique. Although the part number is the same on both hardtop and convertible, they will NOT interchange. The angle of the front windshield is different for hardtop and convertible. The screw hole on a hardtop piece is not in the same location as for a convertible piece.
Offline TelisSE440
« Reply #6 on: January 18, 2016 - 03:04:50 PM »
If you can use the hardtop one, do it, just a little trimming, it would be hard to find a convertible one, not to mention the price.
Offline 1 Wild R/T
« Reply #7 on: January 18, 2016 - 06:23:22 PM »
Believe all you want, they are the same, windshield angle is the same... B body windshield angle is different E body isn't...
Offline crocha617
« Reply #8 on: January 18, 2016 - 07:35:10 PM »
I agree they should be the same I've done it before with no problems.
« Reply #9 on: January 19, 2016 - 03:25:17 PM »
i got one. from a ht
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #10 on: January 20, 2016 - 12:12:49 AM »
Hard-top trim piece is cut/trimmed for Conv.  That's how it was done at the factory.  There is a faint line on the backside of the HT trim piece indicating where to cut/trim. However, the '70 is unique in that it has a different screw hole location than the other years.  I used a non-'70 HT pair of "A" pillar trim pieces, cut them for my Conv, and drilled a new hole in the "A" pillar to attach the trim.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline JayBee
« Reply #11 on: January 20, 2016 - 09:52:01 AM »
 :iagree:  Exactly.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline waskier
« Reply #12 on: August 09, 2016 - 09:23:23 PM »
My 70 convertible Bcuda's RH pillar moulding is cracked right across the hole and completely severing the panel into two pieces.  Luckily I had a spare set of coupe mouldings.  They don't fit, the hole locations are different. Will a 70 coupe panel have the lower mount hole?
Offline brotow
  • There really is a Challenger in the backround
« Reply #13 on: August 10, 2016 - 06:19:37 AM »
I have a pair of repop hard tops(not for sale) I was going to replace my damaged originals. Instead I experimented with fiberglass resin to repair my original broken piece. The repops are different where they meet the dash, the "larger finger" is the most different and the inside radius is off quit a  bit, heating them up with a heat gun may help "adjust the  large "finger"  The last picture is the burnt orange originals after painting black.
« Last Edit: August 10, 2016 - 10:15:08 AM by brotow »
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline VTMopar
« Reply #14 on: August 12, 2016 - 11:45:46 AM »
I've got a couple original sets - very nice ones.....  They are white, but painting/dyeing them is easy.
Send me an email at dwacek@comcast.net
Thanks
VT Moper
VT MOPAR
